Busker991:
THANK YOU!!!
It works now, thank you for finding that extended explanation on how to get it installed!
So happy to have found this solution of yours!
So happy I registered just to be able to say thanks!
Busker991:
THANK YOU!!!
Just put together a new computer. Internet worked - everything seemed fine - then I noticed all of my downloads were corrupt. I reinstalled the system checked ram / hdd / firewall/ all windows settings. Did a couple of wireless adapter tests - seemed fine, but still had corrupted downloads.
I stumbled over this thread and out of pure frustration installed the ralink drivers as explained above. And voila - working like a charm!
Thanks so much!
werki
Thanks all for your contributions to this thread, like many I have just spent the best part of a day battling with this troublesome piece of hardware. I tried the solution mentioned on this thread but to no avail.
My problem I suspect is slightly different as in I could not get the overpriced Belkin F5D8053 N to detect any networks at all.
I stumbled upon these threads
Windows couldn't automatically bind the IP protocol stack to the network adapter. - Microsoft Windows 7 Community Forums - Win7 Heads
same protocol stack to wireless adapter binding failures on multiple Windows 7 64 bit systems and multiple USB wireless adapters
The problem for me was Zone Alarm (grrrr), others have had same problem with Kaspersky (I suspect other virus defence / firewalls will have similar problems).
I uninstaled Zone Alarm and the wireless networks appeared and everything started working instantly. Good times!
Thank you Busker991 you have saved me many hours. I am 66 years old and disabled. I bought a Belkin F5D8053 v3 dongle and was told it was broken. So I belived the person and bought another Belkin F5D8053 v6. This did not work either. I spoke to PC World they said sorry speak to Belkin I did they said we are here 24/7 but took one week to answer. Download the drivers they said I did still did not work. I followed your instructions to the letter and guess what my dongle connected and I can use the web without cables again. I went back to Belkin for 24/7 help all I get is the chip on the v6 is not Ralink and did not say which chip. It is a Realtek (RTL8188SU). So Belkin said download the v6 drivers. Still don't work and with v3 I can only connect at 54Mbs not upto 300 as advertised on the v6(I might get 100 if it would connect) So my question is can you write similar instructions for Belkin F5D8053 v6 PLEASE? I have downloaded the MAC software as their Forum suggested that it might work. I can't make it work. I told the SENIOR Belkin person that I should not have to ask Forum members for help but not even a thank you for your help from him. I would throw the 3 Belkin USB dongles in to the Land Fill but for the cost from my Pension. Better a slow connection than none. I thank you again and all the members for the help. Best wishes from UGGY That looks more like me!!
Just wanted to give my solution. The recent driver did not work for me. I tested some of the older ones and finally on the v3 driver i got my Belkin to work!
Hi, I was having major problems trying EVERYTHING to get this belkin stick to work on my XP machine, and was led to this forum. While the XP installer meant I couldn't follow the steps above exactly, I modified the Ralink drivers to let XP install them for this Belkin stick. Works fine for me, I hope it helps any other hapless xp users suffering with this adapter- README included.
http://www.castlecake.co.uk/download/WorkingBelkinF5D8053driver.zip
-Peter
