External HDD/DSKCHK problem/question.
Page 2 of 2 FirstFirst 12
  1. Posts : 64
    Win 7 Pro 64 bit
    I checked several files with GDB and they all opened with their respective folders.
    I was looking for an option to restore only one folder with subfolders from the Lizzie Archive folder in the image. I selected the option to view files in the image, as I didn't see the option in the Restore section to select that folder.
    As shown in the left window, it's the folder called 101 B10 MediaWorx, opened as H drive by Reflect. I want to restore it to the new Seagate drive, which my wife has already put files on. I had created a partition on the drive to restore the full image to, but when I got to the final step in that restore process it said it was going to erase data on both partitions, even though I had selected just the one partition I had just created, so I cancelled that and changed it back to just the one partition.
    Thank you again!
    Attached Thumbnails Attached Thumbnails External HDD/DSKCHK problem/question.-files-reflect-image.png
  2. Posts : 7,060
    Windows 7 Home Premium 32 bit
       #12
    I think @Bree should be able to help you with his expertise.. ( I had never attempted to copy partition or copy files from an image and as such not qualified )
  3. Posts : 64
    Win 7 Pro 64 bit
    Neither have I, as in the past I have only done full image restore when upgrading to a bigger drive, or a new computer.
    miztrniceguy said:
    It seems that when selecting the file and folder restore option it then looks for an *mbak file to retrieve folders from and doesn't see the .mrimg file
    - - - Updated - - -
    - - - Updated - - -
    I may have figured it out. It seems I needed to create a backup file (*mbak) from the .mrimg file and then will be able to restore from that. It's in process, as that folder is the bulk of the files.
  4. Posts : 649
    miztrniceguy said:
    I was looking for an option to restore only one folder with subfolders from the Lizzie Archive folder in the image. I selected the option to view files in the image, as I didn't see the option in the Restore section to select that folder.....
    The simplest way to restore some of the files and folders from a Reflect image is to mount the .mrimg file as a virtual drive. You can then just use File Explorer to copy the files/folders that you want. Double-click on the .mrimg file to mount it. Make sure you tick the box to enable access to restricted folders.
    External HDD/DSKCHK problem/question.-image.png
      My Computers
  5. Posts : 64
    Win 7 Pro 64 bit
       #15
    Thank you Bree and Jumanji for your help. I have recovered all the files and formatted the faulty drive, and will return it tomorrow. Now I can concentrate on watching my Chiefs figure out who is gonna make the team as wait for the season to start! #3peat #ChiefsKingdom.
    Have a good week!
  6. Posts : 7,060
       #16
    Hail Bree who took you on to the shore and good luck to you. ( I am totally innocent of "#3peat #ChiefsKingdom- something to do with football ????".)
