IDE drive caddy problems
Hi
I have just fitted a internal ide drive caddy so i can use some of my old IDE hard drives as backup drives, but alas i can't get it to work, power lights is on & i can here the drive spin up when i first slide in the tray with drive in it, but can't see it in my computer i have checked ide cable seems to be in fitted ok (brand new one) I thought it might be jumper setting as it was set as master so i removed pin still nowt. Its a pluscom mr-ab, i have two hard drive in comp, both using sata & dvd uses sata so this is only ide device i have, running win 7 64bit. any help muchly appreciated. Thanks
