Memory Card HUB shows problem with files entry
Hello Sevens!
I have new problem with my PC. Long tiome ago I have bough Trust 5.25" Media Connect Bay CR-3600. From few days ago I have problem. My SD card slot doesn't work propertly. I can see (open) fiels prom Card SD, but I can't move or delete them. I have also MS and CF slot and I can open, move and delete files. I have changed USB slots, which connect bay is connected to and problem still exists.. I have reconnected wires in Connect Bay and it didn't solve problem.
What should I do to solve this problem and be able to move/delete files from SD cards. I'm using frequently SD cards, so I need to repair it.
