Sony Vaio battery problems.
ritz
2:35 AM
Hey guys, im not sure if this is the right section or not but oh well.
I have a sony vaio VGN-NR31J/s laptop, and i recently installed Windows 7 ultimate, it runs perfectally but im having some issues with my battery.
First problem is that i only get about 30-40 minutes maximum battery life, opposed to the 3 - 3.5 hours i had on vista.
The other problem is that it takes a whopping 5 hours to charge back up!
i have no idea whats causing these problems, i have installed the most up to date drivers for everything, installed sony vaio power management and tweaked every setting possible, but still no change.
Any help would be GREATLY appreciated, thankyou.
Ritz
windows 7
windows 7
With Lithium ion batteries, you will want to turn off sleep and hibernate and drain them once per month.
Completely drain the battery, then fully charge it.
It will help, but it may be beyond repair if you have never done this.
It can't hurt to try it.
You can also go in to advanced power options and change the settings on the battery.
Good luck. Hope this helps in some small way.
Windows 7 Professional x64Intel Core i7 8604GB DDR3 Mushkin 1600Mhz @ 7-8-7-20MSI GTS250 1GB DDR3 Twin Frozr
Keeps changing - (Custom)
Intel Core i7 860
Gigabyte GA-P55-UD4P
Onboard realtek
Samsung SyncMaster 24" P2450 + Samsung 20" 2033
1920 X 1080 and 1600 X 900 (#2 system 1440 X 900)
Patriot Inferno 120GB SSD + 3 WD Blue 640GB drives
Corsair 750 HX Modular
Lancool PC-K62
Cooler Master TX3 CPU cooler and 4-140mm and 1-120mm case
Gigabyte USB keyboard
Microsoft wireless laser mouse 5000
7 Mb down 1.5 up
System #2: AMD Phenom II X6 1055T (Freezer 7 Pro cooler) - Gigabyte 880GMA-UD2H - WD 500GB Black - 9500GT (1GB) 500W OCZ modular PSU - Antec 200 case. System #3 (LapTop) Core 2 Duo T6670 - 320GB 7200RPM HD - 4GB DDR3 RAM.
