Devices not well configured !! help... (using hp/win7)
shafichariri
12:12 AM
i hope i am in the write forum(plz direct me if i'm in the wrong one...)... !
i have a "HP pavilion" HP pavilion dv2913cl ( this is wat it said on the bottom, however on the screen i have dv2000 ! its refurbished )
so the laptop originally had windows vista 64bit, but i installed WINDOWS 7 64bit.
However this is my problem : in the "device manager" there is always these "other devices"->/1.Base system device (!)/2.Base system device (!)/3.Coprocessor(!)
anyone can help me ?? define these things or i don't know what ?
is this a problem ? might this cause a game to go out to the desktop with this msg "nvidia recovered from an error..." cause this sometimes happens and i have the latest Nvidia driver installed...and all windows updates are installed to.
hope u can help ...
windows 7intel atom inside1 GBbuilt-in
(point of view) MOBII NB9010
windows 7
intel atom inside
1 GB
built-in
built-in
160GB
LAPTOP !!! not a platform
Hello,
I did a Google search for find unknown devices, and I came up with this link: Unknown Device Identifier - Freeware Download
Go ahead and give that program a try. If it works well for you, I may add that in my bookmarks. :D
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
