Increasing mouse speed beyond the arbritrary maximum
  1. Posts : 110
    Win 7 Home Premium (OEM) - Install date: 02-2010
    Is there a utility that I can use to increase my mouse speed beyond the maximum that can be set in the Control Panel? (Win 7).
  2. Posts : 28,845
    Win 8 Release candidate 8400
    I would think that limit is set in the driver and is the maximum that the mouse can handle.
  3. Posts : 846
    Windows 10 Pro
    Can I make my 50 mph motorcycle go faster? NO
    Are you talking about the speed it crosses the screen?
    If so what type of mouse do you have ball. laser or ?
    You can increase the movement speed in the Control Panel under Mouse.
  4. Posts : 110
    That's a little abbrasive, Iggy. My question does not pertain to motorcycles and no comparison can be drawn between them. The mouse is a touchpad, but I don't think it's relevant. Like I said, I've set it to the maximum in Control Panel and I want to go beyond that maximum. TweakUI allowed this for Windows XP. I'd like a similar utility or work around for Windows 7.
  5. Posts : 846
    Windows 10 Pro
    Sorry if I sounded abrasive but I was just trying to show a compaison.
    Originally you said you had a mouse. Now you say you have a touchpad.
    Definitely two different types of hardware.
    I have a multi dpi laser mouse and the most I can get out of it is 2000 dpi. It won't go any faster because it is a hardware issue and not a software issue.
    I'd still like to see what others may suggest on your solution.
  6. Posts : 21
    Windows Se7en Ultimate 7600.16385.090713-1255 (x86)
    Did your try TuneUp Utilities 2010? It's not a freeware, though.
    Good-luck :)
  7. Posts : 11
    Windows xp, Windows 7, Fedora
    Same problem here, I would like the mouse to go faster.
  8. Posts : 13,354
    Windows 7 Professional x64
  9. Posts : 110
    Hey JK; in the registry, mousespeed was set to '1'; I increased it to '2' so now when I restart, the speed should be double. I left the thresholds as they were. Thanks :)
    WiNd0Ws7, thanks for the suggestion but no, it didn't feature a mousespeed option
  10. Posts : 13,354
    I'd be interested to know if it works. Would you mind just dropping a quick reply here with the results?
