Increasing mouse speed beyond the arbritrary maximum
Is there a utility that I can use to increase my mouse speed beyond the maximum that can be set in the Control Panel? (Win 7).
That's a little abbrasive, Iggy. My question does not pertain to motorcycles and no comparison can be drawn between them. The mouse is a touchpad, but I don't think it's relevant. Like I said, I've set it to the maximum in Control Panel and I want to go beyond that maximum. TweakUI allowed this for Windows XP. I'd like a similar utility or work around for Windows 7.
Sorry if I sounded abrasive but I was just trying to show a compaison.
Originally you said you had a mouse. Now you say you have a touchpad.
Definitely two different types of hardware.
I have a multi dpi laser mouse and the most I can get out of it is 2000 dpi. It won't go any faster because it is a hardware issue and not a software issue.
I'd still like to see what others may suggest on your solution.
Did your try TuneUp Utilities 2010? It's not a freeware, though.
Good-luck :)
Same problem here, I would like the mouse to go faster.
Here you guys go: How to make mouse even faster? [Archive] - Server Watch Forums
~JK
