Windows 7: Hard Drive Problem. Need advice
07 Feb 2010   #1
Xp, Vista, 7
Ok, my computer HD recently had an accident.
I accidentally dropped my laptop, the hard drive started to act weird. None of my OS's would boot until i did scan disk, and then it worked. but if I do anything on one of my partitions, drive (D), the HD goes "Click.. click.. click"
I used " Chkdsk /r " in command line to see if I can skip over those areas, thinking they were bad sectors, but it doesn't work.
My HD never clicks anywhere else, only on drive (D)
Will my HD last if I don't use drive (D)? Or should I buy a new one ASAP?
08 Feb 2010   #2
I'd back my stuff up and get a new one ASAP. Clicks from a HDD are NEVER good.
08 Feb 2010   #3
64-bit Windows 8.1 Pro
Quote   Quote: Originally Posted by mlevy View Post
+1 .. that drive has taken a fatal hit.. backup and replace... sorry
08 Feb 2010   #4
Backup your data.
A low level format will give your hard drive more time, but failure is imminent.
Search this Thread:
Advanced Search
Hard Drive Bay Advice - 2TB Mirroring Drive
Hey guys, First post here on the Win7 Forums. I've been lurking around for quite some time, got a little help with quite a bit of issues, but here's a first for me that I don't quite know how to describe. So a bit of background: I work for a church. Our video producer has a Mac Pro. He...
Hardware & Devices
Hard Drive Advice
I was wondering if i could ask some advice on a few people on my future Hard Drive choices. My PC is currently using 1TB WD Caviar Black @ 7200rpm Works PC is running a Seagate Barracuda 500GB @ 7200rpm And my bro's PC i built is same as mine but 500GB Cant help but notice that mine...
Performance & Maintenance
advice on hard drive detection problem
a few months back my computer was working fine but one day it suddenly rebooted with a disk boot failure message. when this happened both my OS drive and my data drive were not found by bios. so both appeared to fail at the same time. when i tested the drives on another person's PC both...
Hardware & Devices
Hard Drive Advice
Hi Folks. With prices being so low at the moment I was thinking of getting another hard drive and would like some advice. At the moment I have 2xSamsung HD501LJ drives. One is half full of my Vistax64/Windows7 7127 dual boot plus a growing collection of games. The other has all my music,...
Hardware & Devices
Hard Drive Advice please
I just got a bunch of new storage today 1 ea Fantom Greendrive Esata External 2tb and a 1.5 tb WD15EARS w/ 64mb Cache. I usually manage my system and os's through partitioning and storing nothing on my C:// drive aside from the OS and installed software this way I can change reformat...
Hardware & Devices
External Hard drive-advice
l have finally bought a WD My Book Essentials 1TB with both USB 2.0 and USB 3.0.Can anyone help me re setting this up or is it simply plug in,connect and off you go? l have a Desktop Computer running Win 7 Professional and the main reason l bought this 'external Hard drive' is l am sick of the...
Hardware & Devices
