Hard Hardware Problem
  1. Posts : 9
    Windows 7 ulti 64 bit
    Basically a computer has 2gb of ram 2 more gb of EXACT ram is place inside the computer,
    when started it MASS reboot and only staying on for 8 seconds tops.
    Now with the new 2 gb of ram removed computer wont boot up ( so its back to normal)
    edit: A disk READ error has occured,
    There are 2 WD Velociraptors 300gb WERE in raid ,well it was till i was forced to change the bios,
    Windows 7 repair tool does not find and recongise the hard drives
    In Bios advanced cmos settings the raid/achi settings is disabled, if it any of the options it will just freeze, with only 1 of the veloci's being detected
    Basically how the f do i make windows 7 load up without a disk error has occured
    If you need more info just say
    windows 7 startup repair how long does it take?
    I'ved tried the bootthingy fixmbr thats one says successful
    fixboot does not work says element not found
  2. Posts : 867
    XP, Vista, W7 64bit Home Premium
    Your missing your raid drivers they may need to be installed specifically during install - post your system specs so we can help.
  3.   My Computer
  4. Posts : 9
    The system was already running windows 7 ultimate FINE before the new 2gb of ram was placed inside
    system specs
    q6600
    OCZ ddr2 6400 1gb x2
    MOBO gigbabyte x48 dq6
    GPu evga 260
    all default settings no oc or nothing now
    how do i check if raid drivers are somehow missing when it was working before?
  5. Posts : 9
    MORE Questions how long does start up repair take?
    In system recovery tools it says
    Operating system unknown on (unknown) local disk
    whats is it meant to say and the screen before, i cant see a harddrive even though ive tried installing the raid ddrivers again via a floppy disk, normally would you be able to click on a harddrive?
    How long does startup repair take to complete
    Thanks in advanced
    Some update
    from the start up repair
    Root cause found:
    MBR is corrupt
    Repair action Disk metadata repair
    Result: failed Error code = 0x2
    Time taken 0ms
  6. Posts : 11,408
    ME/XP/Vista/Win7
    Do startup repair 3 to 4 times.
  7. Posts : 9
    Tried it fails giving the same error
    Strange problem if i only use of the the HDD in raid mode it will get pass the bios and boot from either the dvd or HDD giving a disk error has occured
    If i use both of the HDD the bios crashes before i can press DEL which open up the bios screen.
  8. Posts : 9
    gave in and deleted the raid partions and reput it into raid
    basically reformatted. .............
    and it solved the problem
