Windows 7: Problem with W7 Pro and USB device ?
11 Feb 2010   #1
Windows 7 Pro 64bit SP1
Hope this is the proper forum...maybe a BB user out there...?....Have Windows 7 Pro PC and BB 8330 (Device Manager time I click the W7 USB removal/disconnect/eject icon I get the following error:
"The 'Rim Blackberry SD USB Device' device is not removable and cannot be ejected or unplugged"
Have read where improper USB disconnecting from Windows USB port can damage/corrupt data and or USB device ?
Is there a patch or correction for my 8330 and/or Windows Seven so the BB is recognized and allowed to properly "eject" from Windows Seven usb ports ?
11 Feb 2010   #2
Microsoft MVP
Find out which process issues that message (use Process Explorer). Then we might be able to get closer to the problem.
Here is how PE works:
If you open PE, on the top you find an icon that looks like a radio button. You grab this icon and drop it over the message window. In PE, the process that has issued the message will be highlighted in light blue. If the process name does not mean anything to you, I suggest you Google the name. You can always find a definition on the web. You can also right click on it and go to Properties - then you get more info.
11 Feb 2010   #3
Took a little bit to figure PE out...This is the screen shot of the action that pops up ? ( Also noticed there's a number of other items in the "light blue" ...does it matter ? )
In addition to this problem...when I plug the BB into the USB port...I do not get the USB REMOVAL icon to pop up as it does with other USB devices that are plugged into any USB slot ?
Have tried this in various USB ports...always the same....I do get the Windows little sound notification both plugging in/out...but no USB eject icon appears ?
Also...all USB boot options are disabled in the BIOS. Device shows up in Device Manager/USB Controllers and has latest Windows drivers.
Thanks for your help....
Search this Thread:
Advanced Search
Device (Camera) problem
When the Camera gets (USB) connected. Windows can detect it, but there is a problem with the drivers. By the way of the control panel: hardware and sound, devices and printers, the trouble shooter will fix the problem by reinstalling the drivers. This process is necessary every time the camera gets...
Hardware & Devices
This device can run faster...USB problem
Hello, Since a couple of weeks a get the message "this device can run faster" when I plug a external HD or USB stick in the USB ports of my laptop. Its not only a warning, the transfer speed is also a lot slower as it used to be... Now, cannot recal when it started exactly and if I did...
HL-DT-ST DVD-RAM GSA-H55N ATA Device Problem
I have a problem with my DVD Room, HL-DT-ST DVD-RAM GSA-H55N ATA Device. It won't read blank CD's/I can't burn on blank CD's nothing, but on DVD i can :/ What's the probleM? Can u help me to fix it, please? Thanks.
Hardware & Devices
New USB HD Unknown Device problem
Hi Guys Have read through a lot of post, I have similar problem with several threads but I'm more confused now. I have 3 External HD and one Semi-External (backup unit HP). None of them works through USB ports (none of my 4 ports). Not even the four different Mem sticks I have tried works. ...
Hardware & Devices
device manager problem
Im using windows 7 home premium 64bit I have such a problem: when I go to device manager and select anything there I cannot see anything else besides the resources tab and the resources tab says such a thing: Any help is appreciated
Problem with device drivers
i recently put Windows 7 Build 7000 on my Acer 5100 laptop, and i love it. the only problem i am having out of it is i can't get any of my USB's to work on it. i have tried nearly everything that i can think of to try to get them to work, and have succeeded twice, only to be let down later. the...
