i have the problem about my battery....the battery icon show the message "consider replace your battery".... but before today i have no problem with my battery.... please help me.... why is it happened and how to overcome this problem.... tq..... the X mark on battery icon is annoying....
It is a known problem in win 7 especially with panasonic laptops. It doesnt have a fix yet.
hi khairi90, one of the members aem posted this tip "in device manager, disable Microsoft ACPI-Compliant control Method Battery" hope that helps you in some way
System Manufacturer/Model Number self build OS win 7 ultimate CPU amd phenom x4 9600 Motherboard asus m2n32-sli deluxe Memory corsair twinxs 2x2gb Graphics Card 2x nvidia 1gb 8500gt Sound Card onboard Monitor(s) Displays 19" lg ring tft
PSU oryxx tornado 750w Case thermaltake xaser lll Cooling artic freezer64 pro + 7 case fans Hard Drives maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
maxtor sata 320gb
fujitsu sata200gb
Are you positively sure the battery is not dieing? They do not last forever you know...
If Windows is saying it is, then the hardware is saying your battery is going...
* Disabling anything in Device Manager without expert knowledge should not be done under any circumstances!
Computer type PC/Desktop System Manufacturer/Model Number Alienware Aurora ALX R4 OS Windows 7 x64 (SP1) CPU Intel Core i7-3930K (3.2GHz, Turbo 4GHz) Motherboard Alienware Aurora-R4 x79 Memory 4x Samsung 4GB PC3-12800 DDR3 (16GB 1600MHz) Graphics Card Nvidia Geforce GTX 690 (Stock) Sound Card RealTek Integrated Audio Monitor(s) Displays Dell UltraSharp U3011 Screen Resolution 2560x1600
PSU 875W Some Dell PSU <.< Hard Drives Samsung P830 256 GB, WD Raptor 150GB, 2x 1TB HDDs Other Info Dell Inspiron Mini 10v (Intel Atom N270 1.6 GHz; 1GB; Windows 7 Ultimate)
