Weird Bootup Problem..
  1. Posts : 9
    Windows 7 x64
    I've been having some problem with my pc recently.
    I built it 2 months ago and had no problem with it until recently.
    When I shut down the computer, after a few hours when I turn it back on, it won't boot. All the fans graphic card and hdd are on, but no beep signal. But when I turn off the power supply and turn it back on it boots fine. Another thing I noticed is that if I shut down the computer and maybe wait 10 min and turn it back on it works.
    I suspect maybe the psu or the Motherboard but I'm not sure since I have no other problem and it used to work fine.
    Hope you guys can help
    Here are the specs CPU-Z Validator 3.1
  2. Posts : 1,506
    W7 Ult. x64 | OS X
    I'd suspect your power supply before your motherboard. I don't know of any power supply diagnostics other than simply diagrams.
  3. Posts : 759
    Windows 7 Enterprise x64
    Looking at your specs, I see your running an OCZ 600w PSU. I would be shocked and amazed if that PSU was failing. I would suspect a bad connection somewhere before I went pointing a finger at an OCZ product. I have purchased many OCZ products, and not one has failed me yet. I'm not saying it can't happen, but it's pretty rare. Check all your connections.
  4. Posts : 3,487
    Agreed. I have a 600W OCZ. Best PSU I've ever seen for the price. It's almost bullet-proof.
  5. Posts : 759
    I'm running one in my primary rig as well [see specs]. I swear by OCZ products.
  6. Posts : 3,487
    I do too. I was using the platinum 800 RAM sticks and loved 'em. The ones I have now were a gift (thanks mom) and were cheaper than the OCZ 1066 ones at the time. They're nice, but I had to RMA the first set. I should have put in the extra for OCZ.
    If OCZ started making motherboards, they'd be unreal.
  7. Posts : 759
    RAM has got to be listed right up there in the ranks for the perfect gift. Gotta' love Mom for that one! So yeah, I would use them too. Plus it's the whole thing that Mom bought them for you. Gotta' use them!
    OCZ memory modules is the only brand I buy anymore. If I can't currently afford it, then I wait until I can [while constantly checking for sales]. There is simply no substitute for OCZ memory. When they started making PSU's, I jumped on those too. And yes, if they started making motherboards, my next rig [I want a socket AM3, with a quad core Phenom] would be a total OCZ build.
  8. Posts : 9
    Windows 7 x64
    OK, basically I found a workaround so that I don't have to reset my PSU every-time I start my pc.
    Instead of shut-down I just hibernate the computer and when I turn it on it works. I'm still curious of what might be causing the problem.
