HIGH speed USB hub running at FULL speed.H
wr332
6:33 PM
after dealing with PCI usb hub. i went and got external usb hubs and yes it worked on windows 7, but only FULL speed, my cam went from fast to laggie, iphone connect to usb hub had a message " it can perform faster if connect to a high speed port" , i check under device manager and it says " the device is operating on FULL SPEED "
i have check online, full speed = 12 mb/s , high speed = 480 mb/s
are there any ways to change this?
windows 7pentium duo core 24Gnvidia 7800 gts
windows 7
pentium duo core 2
asus p5g41-m le
4G
nvidia 7800 gts
onboard
samsung 220wm
1 raptor 150G
1 hitashi 1500 G
n/a
n/a
First question... Are they high speed hubs?
I have an older 4 port Dlink here that's never run 480... looking into the chip on the internal circuit board, it turns out to be a 12mbps chip... you can slow them down, but you can't scare them into running faster.
XP Pro SP3 X86 / Win7 Pro X86Amd 64 x2 4200 (2.4ghz)Kingston DDR2 800 2gbNvidia GF-8400
Homebrew
Asus M2N-MX SE Plus
Nvidia GF-8400
Realtek on Motherboard
Acer x-193bw
1440 x 900
Western Digital 500g
350watt In-Win
In-Win
Air
yes
yes
5mpbs
Also ASRock ION 330 as HTPC (on XP).
Acer Aspire as GP netbook (on XP).
Most hubs can't run high speed anyway. They're connected to another usb hub whose maximum speed is high speed. This means that they can't possible go high sped because there's anywhere from 2-7 devices plugged into one port. Now, if you have a PCI USB Hub then you've got a real high speed hub.
W7 Ult. x64 | OS XIntel Mobile Core 2 Duo 2.93Ghz [T9800 Penryn]4096MB Samsung DDR3 Dual Channel [PC3-8500F 1...NVIDIA GeForce 9600M GT 512MB [G96M Rev. C1]
Apple Macbook Pro (April 2009)
W7 Ult. x64 | OS X
NVIDIA nForce 730i Rev. B1 [Mac-F2268EC8 (U2E1)]
4096MB Samsung DDR3 Dual Channel [PC3-8500F 1066Mhz]
SB X-Fi Surround 5.1 USB | Onboard Realtek (Disabled)
Acer x223wbd 22" | Apple Anti-Glare 17" (Disabled)
{Current} 1440x900 {Acer} 1680x1050 {Apple} 1920x1200
{Internal}
Seagate Momentus 320GB 2.5" 7200RPM [ST9320421AS]
{Externals}
LaCie 320GB USB 2.0 HDD [301284UR]
LaCie 750GB USB 2.0 FW400 eSATA HDD [301314U]
LaCie 1TB USB 2.0 HDD [301304UR]
Magsafe
Aluminum/Unibody (MBP52)
2 x 6000 RPM Fans
Logitech G-15v2 [PN 920-000379]
Logitech G-9 [PN 910-000338]
12Mbps/2.5Mbps w/ 24Mbps Speed Boost [Comcast]
Logitech X-540 Speakers [PN 970223-0122]
Sennheiser PC-151 Headset
My first question, why did you go to a PCI USB Hub in the first place and did you leave it behind (remove it), like your message suggests?
What is the new hub you bought plugged into, and what is the hub itself rated as? USB 2.0?
Devices have to match USB port speed also to run at that speed.
I too have old stuff with 1.1 ports, including G11 keyboard; for running a keyboard, microphone, or mouse, 1.x is just fine, but for external storage, yes you want 2.0 or even firewire.
I dug a little deeper, and web cams will need a higher speed USB, definitely.
Did you just recently add more USB devices + the hub?
In that case you are using up bandwidth (taking it away from camera) and if it's too much then yes you will start to take a performance hit, and if you are using 1.1 USB instead of 2.0 now, you are definitely taking a step backwards and have to get back to 2.0 or you web cam is doomed to stay a laggy beast.
Windows 7 Ultimate Retail Box (64-bit install...AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was requ...8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo n...Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Fro...
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
