Windows 7 - device & printer panel does not load? |
04-29-2009
#1 | | |
device & printer panel does not load? I installed a fresh copy of Windows 7 (not upgrade). I've tested a few builds over the last few months and 95% of the time had the same problem.
When I click devices & printers from start menu or within control panel, the green status bar in the top window starts to load very slowly and eventually halts at the last tiny bit but none of the installed hardware nor any icons appear in that window.
I have a Sony Vaio VGN-AW190, Core 2 Duo, 4GB memory and 64bit Windows 7.
All my devices appear fine in device manager otherwise and work fine.
| My System Specs | | |
05-16-2009
#2 | | |
I too have the problem of Devices and Printers not loading. This problem just occurred because the icons have been appearing until today. | My System Specs | | |
05-25-2009
#3 | | |
I've same problem. Is there a solution? Thanks | My System Specs | | OS Windows 7 CPU Intel Quad Motherboard Asus Memory 8 Gb |
05-25-2009
#4 | | |
I am not sure why, but devices and printers is loading again on my W7RC. | My System Specs | | |
06-14-2009
#5 | | |
Really weird, when selecting Devices and Printers (Device Stage) in the menu the progress bar would take forever and never display anything - just blank.
Finally discovered it was actually a bluetooth issue in services. I don't even know why I looked there - -
THE FIX at least for me..
Click Start button, type "services" into the search program and files box. This brings up a list in the menu, select Services. This should open a list of local services on your system.., Find 'Bluetooth Service" and make sure it has started, right click and set to 'automatic' (mine was already set), Select "Bluetooth Support Service" and start, set to automatic (mine was set on manual) --
This fixed my issue, hopefully yours as well..
Originally posted by slappydog | My System Specs | | |
06-15-2009
#6 | | |
Quote: Originally Posted by ghost301 Really weird, when selecting Devices and Printers (Device Stage) in the menu the progress bar would take forever and never display anything - just blank.
Originally posted by slappydog Now thats just freaky! worked for me. Thanks alot! | My System Specs | | System Manufacturer/Model Number Alienware OS Windows 7 RC 7100 CPU Intel Core 2 Quad CPU Q6600 @ 2.40GHz, Overclocked to 3.25GH Motherboard NVIDIA nForce 680i SLI Memory 8 GB Graphics Card NVIDIA GeForce 8800GT x2 SLI Monitor(s) Displays Dell 2208WFP x2 Screen Resolution 1680x1050 Hard Drives 240GB, 500GB, 500GB internal
300GB external |
06-30-2009
#7 | | |
Originally posted by slappydog Great find ghost301! Worked for me too! Although my bluetooth still isn't working | My System Specs | | System Manufacturer/Model Number Phoenix Technologies - ECS OS Windows 7 RC Build 7100 CPU Dual Core AMD Athlon 64x2 5000+ Motherboard ECS AMD690GM-M2 Memory 2GB Graphics Card Geforce 8500GT Sound Card Realtek ALC883 Monitor(s) Displays LG Flatron W2252TQ Screen Resolution 1680x1050 Keyboard Bright wireless keyboard 2.4ghz Mouse Bright wireless mouse 2.4ghz PSU 1GB DDR2-667 Kingston + 1GB DDR2 - 667 Kingston Case Desktop Hard Drives Samsung HD161HJ (160gb) Internet Speed 256kbps |
10-25-2009
#9 | | |
omg thanks the fix worked. the panel loads and everything works like it did before!
i suppose this is because devices and printers also loads bluetooth related things, and since the bluetooth service is off, bluetooth doesn't work. So, the devices and printers panel is searching for a reply from the bluetooth driver or w/e and it doesn't get it so it just never loads.
didn't think about this at first, but this seems to be the reason, and the above mentioned fix works great ! | My System Specs | | OS Windows 7 Build 7600 RTM CPU Core 2 Duo @ 2.00 GHz Memory 2 GB RAM Screen Resolution 1280 x 800 Hard Drives 1 x 160 GB
1 x 250 GB |
11-05-2009
#10 | | |
Anyone else having this problem? I tried the fix in here, but I have no service called "bluetooth support service". Perhaps that's a problem. I do have Bluetooth Service, and I set that to automatic.
I just did a fresh intall bringing my Vista machine to Win 7. I do have a bluetooth adapter installed, which seems to be working. And, in all accounts except the admin account, the devices and printers panel works fine/normal. But in my admin account, it hangs up loading the devices and printers view, and never completes, leaving a blank panel. Printer works fine in all printing applications, etc., jut the control panel view for devices and printers does not show anything.
Thanks | My System Specs | | OS Windows 7 CPU i7 920 Motherboard Asus P6T device & printer panel does not load? problems? All times are GMT -5. The time now is 12:39 PM. |  |
