Power problem
  1. Posts : 54
    Power problem
    I have had a problem with my PC recently. It got cut off completly. The only thing I was able to do was to see the startup screen for win 7. The weirdest thing of all this was that I haven't got any blue screens or errors since this one. I'm considering if something very basical isn't configuered the right way in my power options for the bios.
    Power problem Attached Files
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Can you see the bios screen on startup? can you boot into safe mode (F8)?
    Ken
  3. Posts : 54
    Yes, I can see the bios setup.. but I'm such a newbee when it comes to power settings. And yes I'm able to boot into safe mode now,,, because I've had a reinstall
    As far as I know my power settings are configuered right, but I don't know with win 7... The settings are
    these: acpi apic support enabled, acpi 2.0 support enabled.
  4. Posts : 1,747
    window's 7
    check this thread mate
    Power Plan Settings - Change
  5. Posts : 54
    Ken
    I have writen some messages, I forgot to reply the right way:)
  6. Posts : 54
    I've read it, but I'm still confused, isn't it neccessary to change something in the bios?
