Windows 7: Problems when using e-SATA cable with my External HD
01 Jun 2010   #1
shadowman
Windows XP Home Edition 32-bit
OS: Windows 7: Home Premium 64-bit
External HD: Western Digital My Notebook Home Edition 1 Tb Model# WD10000H1CS-00
Motherboard: ASUS M2N-SLIDELUXE
Problem: When I use the e-sata cable on my external HD half of the time I'll experience data corruption or what seems like data corruption exg. pictures will not open in Irfanview (gives a missing handle error etc.), picture thumbnails are wrong and show incomplete pictures. After I took the e-SATA cable off and put it back onto the setup I had before using the firewire cable I don't have the error handles and files not loading etc.
I like how the e-sata cable is a bit faster than the firewire cable but this is a problem I can't seem to understand. Can someone tell me what to do in this scenario?
I've seen things about the JMICRON drivers or something like that but I don't want to mess around with anything especially essential drivers if I don't know what I'm doing. also I might add that I am running everything in IDE. AHCI wouldn't work when I changed to that in the BIOS. I got a "cannot locate operating system" error.
04 Jun 2010   #2
shadowman
could someone please help me try to understand what is wrong?
04 Jun 2010   #3
Sanvean
Windows 7 Professional 64
Hi shadow,
Can you try a another cable, possibly shorter? Long cables are known to produce corruption.
Last fall, I was getting corruption and errors logged due to my external. Replaced the cable and the problem went away.
If you do need help with Jmicron, I can assist you with that. I'm off to work soon, but will check back here later.
09 Jun 2010   #4
shadowman
I just bought the cable though so I think its unlikely
10 Jun 2010   #5
Mark Phelps
It's probably NOT the cable, but instead, the motherboard.
I have an older A8N32-SLI ASUS mobo and could not get the E-SATA to work reliably on it, either. I spent months reading the ASUS forum, but no one came up with a reliable solution.
It's likely a problem with the E-SATA chipset used on the ASUS boards.
SATA HD To USB Cable (External HD To PC)
Hi, Have about given up with my Seagate external HD (FreeAgent), but saw a post where the poster mentioned that the drive (his) was apparently mechanically fine and that it turned out to be the electronics inside the HD case. (My Free Agent External HD has a separate power wart, and a dc...
General Discussion
Safety of internal 3.5 Sata IDE in external Sata case for backups
I'm looking at a Sabrent EC-UEIS7 Hard Drive Enclosure - 3.5" IDE/SATA to USB 2.0, eSATA in order to use one of my now internal Sata drives as an 'external' backup device. If I turn the external power off on the back of the external Sata enclosure with my extra old Sata connected in it...will...
Hardware & Devices
Is this a SATA 2 or SATA 3 cable?
Hey, I got a new case today and it has an eSATA port on the front, the cable it is connected to is... NEW 20 inch - Serial ATA SATA I II Red 7-Pin 7PIN Data Cable Copartner AWM 21149 26AWG E119932 80C 30V VW-1 I was wondering if this cable was a SATA 2 or 3 'cause I like to...
General Discussion
Sata/IDE to USB cable
I bought one of these today off eBay but then noticed the description says not comparable with vista and windows 7. But surely windows 7 should just find it on its own? Please let me know ASAP as I'm worrying I bought wrong one. Thanks kent.
Hardware & Devices
Thin Sata Cable
Does anyone know where I can find a sata cable where the plug is the thin all the way through? I think the one that I am using now will become unplugged every so often and my computer is getting a BSOD. I do notice that when this happens, the cable is loose and not snapped in like the 3.5" drive I...
Hardware & Devices
Sata Hdd / cable / motherboard sata / problem?
Relatively new hdd disappears after some time. (1Tb WD black sata3 jumpered to sata2) All cables are sata click. The drive is used for storage and is accessed only few times a month. So is any way to test somehow what is the problem hdd, cable or mb sata connector (GA-EP43-DS3L). It's all...
Hardware & Devices
