Failure of Firmware Upgrade of Samsung DVD Writer using Win 7 (64bit)
I want to upgrade the firmware of my new Samsung DVD writer (from Toshiba Samsung Storage Technology) to the latest version.
DVD writer Model:
TSST corp CDDVDW SH-S223C
For some reason it will not burn DVD –RW disks.
So I downloaded the latest appropriate firmware file from cdrinfo.com
Namely SH-S223C_SB04.exe which I ran under win7 (64) bit OS
This executable program in turn started up “Tsdnwin.exe” installation program which then crashes (freezes) the system.
I had to use the Windows “Task Manager” to End the Task.
Can this be a compatibility problem for win7 64 bit OS?
Or is my Win7 OS somehow corrupted?
Next I installed and tried ODD FW Liveupdate program and it too fails with an error message :
“that due to a system problem it failed to operate a program by
automatically connecting to it.”
Can anyone suggest what might be the problem here?
