#31
Yes, you should report it to your motherboard manufacturer and ask for a BIOS update. I wonder if you're refering to the amount of memory displayed on the system properties page (installed memory), rather than the amount of memory that was actually usable on the 7000 build. That would explain why you think that it was working. In reality, you probably never had 4GB of usable memory with that build - you just thought you did. :)
