Need shortcut or way to recognize hot swap drive
donnyb
7:55 PM
I have a removable drive bay that my Win7-64 will not recognize when I insert it and turn it on. Here are the steps I take so it will be recognized:
Start
Control Panel
Administrative Tools
Computer management
Disk management
Action
Rescan Discs
After doing the above 7 steps, I can use the inserted drive. So, I would like to know if there is a shortcut for the steps or is there something I need to change so it will work? BTW, my computer is fairly new (i7 w/6Gb of triple channel memory) and I did have the drive working as a hot swap drive when I had Win XP Pro - 32 bit installed on it.
Win 7 x64i7 920 @ 4Ghz6 GbATI 4770
Win 7 x64
i7 920 @ 4Ghz
Asus P6T Deluxe v2
6 Gb
ATI 4770
1 ea 750 GB
1 ea 1TB
1 ea 750 GB
1 ea 750 GB
No Raid, all SATA
Corsair TX750
Coolermaster ATCS 840
Prolimatech Megahalem
Start
Control Panel
Computer management
Disk management
Action
Rescan Discs
Does the bay/drive require a driver and is it installed, or is it a generic USB?
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Sorry, I didn't specify. It is a SATA II drive. When I had the XP installed, I did not have to use a driver.
Win 7 x64
i7 920 @ 4Ghz
Asus P6T Deluxe v2
6 Gb
ATI 4770
1 ea 750 GB
1 ea 1TB
1 ea 750 GB
1 ea 750 GB
No Raid, all SATA
Corsair TX750
I'm in the same exact position, did you find out the answer?
Windows 7 Ultimate 64 bit
Windows 7 x64 Ultimatei7 96012 Gig Corsair DominatorNvidia 480
Scratch built
i7 960
Asus P6X58D
Nvidia 480
Maudio Delta 44 + breakout box
Dell UltraSharp U2410 24in and Samsung 21 dual monitors
1920x1200 and 1280x1024
Primary: Intel X-25M G2 160G SSD
Secondary: Segate baracuda 1.0 TB
HDs in AHCI mode.
Corasair TX850
Cooler Master HAF
Corsair H50
Logitech G15 + N52 game pad
Logitech MX518
15kbs down 4.5kbps up
WEI 7.6
CPU & RAM 7.6
Graphics 7.9
Hard disk 7.7
Hey Guys,
Having a very similar problem to the OP myself. I just purchased a ThermalTake BlacX hard drive dock with USB 2.0 and eSATA connections. I've connected the enclosure to my Intel onboard SATA controllers #4 and #5. I've installed a Samsung SpinPoint F4 2TB hard drive in the dock. This is an EcoGreen drive, so 5400RPM.
When I first turn on my Windows 7 64-bit machine everything is fine. If I then hit the power button on the Thermaltake dock, the drive spins up, Windows detects it and I have my G drive. The drive works fine and when I am finished, I can click on Safely eject the hard drive and I can power down the dock.
The problem is the next time that I turn on the enclosure...the drive indeed spins up and the lights come on...but Windows doesn't detect it. I have to go into Disk Management and Rescan disks and it reappears.
I've tried connecting this to my Gigabyte SATA ports as well as the Intel SATA ports and the behavior is the same.
I found the KB977178 about Stop Errors in Server 2008 and Windows 7 due to drives which spin up slow. I am running that hotfix, but it hasn't resolved this issue.
Any ideas?
Oh yeah: the behavior is the same if I use USB 2.0 or eSATA.
Edit: The fastest way I have found to run rescan disks is to make a shortcut on my desktop which points to diskmgmt.msc. Then, action rescan disks.
Windows 7 Ultimate x64Intel Q9550 2.83Ghz OC'd to 3.40Ghz8GB G.Skill PI DDR2-800, 4-4-4-12 timingsEVGA 1280MB Nvidia GeForce GTX570
Self-Built in July 2009
23" Acer x233H
Intel X25-M 80GB Gen 2 SSD
Corsair 620HX modular
Antec P182
stock
ABS M1 Mechanical
Logitech G9 Laser Mouse
15/2 cable modem
