Windows 7: Home Premium N key won't work with Home Premium - Help.
10 Feb 2010   #1
Windows 7 Starter
I have windows 7 home premium on a dvd and I installed it on my computer. I typed in the product key and it says it won't work with the current sku, on windows first time setup.
I know that it's a windows 7 home premium N key, because I used a program that told me what it was. So anyways, it won't work with home premium. Why doesn't it work. it is a home premium dvd and a home premium product key.
I tried phone activation but it failed. It is a valid key because microsoft gave it to me. So do I need a special install dvd for windows 7 home premium N? Or is there any way I can get it to work now?
Where do I download a copy of windows 7 home premium n if I do need it?
Thank you all for any help. It's greatly appreciated!
10 Feb 2010   #2
Pembroke
As far as I know Home Premium N and Home Premium have different product keys.
10 Feb 2010   #3
Windows 7 Starter
Is there anything I can do to get this activated?
10 Feb 2010   #4
Windows 7 Home Premium SP1, clean install, upgrade disc
CT
I agree with DarkNova, there are different keys for the two additions.
Try calling the number for your area. You will be given the opportunity to activate by phone. If that does not work a rep should get on the phone
http://www.microsoft.com/licensing/e...n-centers.aspx
If this is the number that you called, we have to devise an alternative solution. Just let us know.
10 Feb 2010   #5
W7, Xp Pro
AUS
OS Windows 7 Starter, why is this in your System Specs??
 Home Premium N key won't work with Home Premium - Help. problems?
Similar help and support threads for: Home Premium N key won't work with Home Premium - Help.
Solved BSOD after upgrading from Vista Home Premium to 7 Home Premium BSOD Help and Support
Upgrading from Vista Home Premium to 7 home premium? Windows Updates & Activation
will key work with Win 7 home premium SP1 DVD also? Installation & Setup
student download vista home premium to 7 home premium Installation & Setup
Upgrade Vista Home Premium --> 7 Home Premium --> 7 Pro Installation & Setup
