32bit to 64bit
  1. Posts : 605
    W7 Ultimate
    32bit to 64bit
    Can I update a current 32 bit version of W7 Ultimate to 64bit? I have the installation disk.
  2. Posts : 3,028
    Windows 7 Ultimate (x64) SP1
    To go from 32bit to 64bit requires a clean install. You cannot upgrade
  3. Posts : 43
    Windows 7 + Windows Xp Pro + Ubuntu 10.04 + openSUSE 11.2
    There is no way to upgrade coz 32 bit and 64 bit are processor architechture dependent.Even if your hardware is compatible fully for 64 bit ,there is no way to change to 64 bit directly, a clean install is the only option !
  4. Posts : 17,796
    If you purchased one key and received 2 DVD's one 32 bit the other 64, you can do a clean install. However, you can only use that key on one computer at a time.
    Clean Install with a Upgrade Windows 7 Version[2]=General Tips
    You can use the method shown in the above tutorial, assuming that you do own a supporting version of Windows, Vista or XP.
  5. Posts : 56
    Win7 32 / 64 and XP 32 / 64 (on various other computers as well)
    64 takes a new install, but the question really is should you go to 64 bit?
    If you list your computer specs and what you do with it we can give better advice. In the end the 32 bit runs a tiny bit faster, takes up less disk space and uses less RAM. 64 bit can address more RAM (more programs at once, but usually no faster) and should eventually be faster than 32 bit. Right now we are in transition, we are 64 bit compatible but not 64 bit optimized.
    Gamer with 4Gigs RAM or less? 32 bit
    Photoshop, CAD, video editor with more than 4 Gigs RAM? 64 bit.
  6. Posts : 605
    W7 Ultimate
    Although I have the processor, memory, etc. I have decided that I doj't want to go through the hassle of a clean install again. Just finished a clean install, about a week ago, of 32 bit.
  7. Posts : 846
    Windows 10 Pro
    Great choice blockie!
    Most of just nead 32bit.
  8. Posts : 11,990
    Windows 7 Ultimate 32 bit
    With 2 G's of RAM, I recommend staying with 32 bit. There would be no gain for you - and less potential driver problems.
