Windows 7: sound volume control problem in WMC
13 Feb 2010   #1
htpc
Hi, I have only one small problem with the sound volume control in WMC. I have a new HTPC, pumpimg sound out via a Digital coax cable to Logitec z5500 speakers. This works just fine, sounds great etc, except..... The sound volume control in WMC doe not work when watching Live TV, or TV accessed from the Guide. In every other WMC circumstance, whether music, recordedtv, videos, slide shows and normal PC noises etc, the sound volume control works just fine. Any ideas???
13 Feb 2010   #2
Shark007
Windows 7 Ultimate 64bit
In order to control the volume from the PC when using spdif digital output, go to the Control Panel | Sound applet and double click the spdif output device.
Go to the Advanced tab, and uncheck the two Exclusive Mode checkboxes.
13 Feb 2010   #3
htpc
Shark007, beautiful, this worked out great!
11 Jan 2014   #4
sdowney717
when you do this, you loose 5.1 dolby surround and all you get is stereo
No audio but the green sound bar on the volume control is moving?
Hey there! A few days ago I changed my hdd because the last one got corrupted and had a lot of bad sectors so I installed a new windows 7 OS. Everything was smooth until the sound suddenly stopped. I wasn't doing anything in particular. I noticed the green bar on the volume control is moving but I...
Volume Control wont move sound card slider
I have E-MU 1212M sound card, Windows 7 and I can't fix this problem which I haven't had before. I reinstalled the Windows 7 and now I can't move my Volume Control and affect my sound card volume. My sound card volume wont move until I move it. It's like my volume mixer is pre-effected,before my...
Creative sound card, windows 7 compatible volume control?
I recently bought a dell computer second-hand from my friend, who had XP installed on it. It came with a subwoofer and a set of 4 regular speakers. On it, he had installed a form of creative volume control in addition to windows volume. The way it worked was he had the windows volume set to 100%...
Green Bar in Volume Control is Moving, No Sound
I have speakers plugged in to my computer running Windows 7 Home Premium 64Bit. The computer is recognizing that I have speakers plugged in and when I play something the green bar moves with the music. However, no sound is coming from the speakers. I have gone into the BIOS settings and enabled...
Sound unmuting when I touch volume control?
Is there anyway I can disable the sound unmuting when i turn the volume control knob? Vista didn't do this and it's really annoying as its on the bottom so i always catch it when the laptop is on my lap.
Volume mixer issue / sound control
Hello guys, I searched the forum for common problems but unfortunately I could not find any useful information for this issue. I hope you can assist me as the Windows 7 volume mixer is freaking me out and I cant seem to find a way out with this... I run Windows 7 on a Dell Inspiron 6400...
