[HELP] Connect Win 7 Ultm - XP Pro SP3 Using LAN Cable
  1. Posts : 20
    Win 7 ultimate
    Greetings to all..
    I'm a new member here. And also this my second day running my PC on win 7 ultimate. Not yet activated.
    This last few hours i've got a lot of dizzy trying to connecting my old laptop with win xp into my PC win 7. And surprisingly win 7 use a new 'method' on sharing files with another computers.
    Usually when i connect my 2 win xp pc, all i need to do is just setting up the IP addres for both pc and then plug up the LAN cable. Done, the xp connect themselves.
    I did this one on my win 7. But it doesn't works perfectly. Both my pc and laptop were connected. i can see them on my windows explore network menu. But i can't browse the containing folder that shared on xp pc. And also on my win 7 pc.
    Basicly, both my pc looks like already connected, BUT I CAN'T browse the shared folders that manually i set up to be share.
    Plese help me how to connect win xp and win 7 ultimate properly.
    Thank you.
    Big regards.
  2. Posts : 557
    Windows 7 x64 Ultimate SP1
    Hi Raditz and welcome,
    Did you add EVERYONE to permissions in Windows 7 shared folders?
    Did you enable network sharing in the advanced Sharing Settings?
    Here is an image. I'm not on my 7 Machine.
  3. Posts : 20
    Win 7 ultimate
    Yes, I did add EVERYONE to permissions in Windows 7 shared folders.
    Yes, I did enable network sharing in the advanced Sharing Settings.
    Now my win 7 PC can browse (read and write) the folder of XP that I shared. But my XP can't browse the shared folder on win 7.
    Does anybody can resolve this?
  4. Posts : 557
    Do you have password enabled activated?
    Try to disactivate.
  5. Posts : 20
    Win 7 ultimate
    Try to disactivate.
    Well.. maybe that was the problem
    Just like the one i found here : Offline files between XP Pro and Windows 7
    I'm a little busy this day
    I'll check it soon.
    Thank you.
    Big regards.
