Windows 7: Slow speed, fast speed, slow speed.
18 Oct 2011   #31
xChase
Microsoft Windows 7 Ultimate 64-bit 7600 Multiprocessor Free
2wire 2701hgv-w. Perhaps the best option is a new router?
18 Oct 2011   #32
Dave Atkin
Ahh I was looking for one of these the other day with no luck! 2-Wire have very poor support on their products from what I have seen.
I would suggest a new router yes. If its just a standard ADSL connection then NetGear have always been relicable in my opinion.
Dave
18 Oct 2011   #33
xChase
Would it be wiser for me to use a D Link router considering that's the brand of my adapter? Or does it really not matter? And what type of router should I be looking for?
18 Oct 2011   #34
Dave Atkin
It shouldn't really matter as the routers will use the same encryption. However, if you are happier getting a D-Link router then go for it.
It maybe worth asking your provider for a recommended router. You need to find out if you're on ADSL/ADSL2+. They will be able to tell you what kind of router you need. I wouldn't buy it off them though as they can sometimes rip you off! If they recommend a 2-wire then hang up lol.
Dave
18 Oct 2011   #35
xChase
Just realised that it's not just the wireless computer, it's all of them. Even the machine connected to the router directly.
18 Oct 2011   #36
2xg
Win7 & Win8 64bit
Quote   Quote: Originally Posted by xChase View Post
A new router is a good idea, you may also try a reset to the factory default setting then reconfigure all from scratch. Do print screens of the router settings prior to the reset.
How to Reset a 2Wire Router | eHow.com
19 Oct 2011   #37
xChase
The settings are exactly the same as they were before I moved house. I honestly don't think it's anything to do with the settings because even the computer that's wired is slow as all hell.
19 Oct 2011   #38
Dave Atkin
As per zxg's post, try resetting the router.
If this fails, try as different router.
Dave
How do I change CD-ROM speed? (Transfer speed is extremely slow)
Hello guys! So I bought this kick-ass laptop from MSI. It is pretty good. These are the specs (in case they aid in finding a solution to my problem): Name: MSI WorkStation Series GT60 2OKWS-674US OS: Windows 7 Professional 64 bit CPU: 2.7 GHz Intel Core i7-4800MQ
Hardware & Devices
Windows 7 internet speed slow on wireless, but fast on wired
I have two Windows 7 Laptops that connect to a Motorola SURFboard eXtreme cable modem SB6121. Suddenlink (cable provider) recently upgraded our network which gives 50 MPS speeds or more. I can only get 50 MPS when I disable wireless on my laptop and connect with a direct cable. Otherwise I get 20...
Network & Sharing
Slow web browsing, but fast download speed - help!
Hello I have a problem with my PC that has been bugging me for a long time. My web browsing is painfully slow on some sites (SharePoint, sage, office 365, linked in etc. etc.), But works fine for others (porn sites, YouTube, google search, eBay, Facebook etc. etc.). It is really annoying as my...
Network & Sharing
CPU fan speed, better fast or slow?
Is it better to have your cpu fan run slow or fast to get better temperature's?. :D
Hardware & Devices
fast download speed but browseing speed slow.
hallo i have a problem last 1 week.my downloas speed well..but browseing speed slow.i playing online games.watch movie. its soo low its too pain full.i cant under stand why?..i am from srilanka.internet line ADSL.. prolink router..512KB/s line..plz help me.
Network & Sharing
Slow download speed under Win7/Fast under MacOsX
Hello, I need to ask for your advice here. I have browsed this forum but none of it helped so far. I am running two operation systems on my Macbook via boot camp. Original MacOSX and Win7 32. I am using my school internet via LAN in the campus where I live. When I do the speed test...
Network & Sharing
