Solved Wireless connection works, wired connection does not.
devzspy
6:02 AM
So last night, my wired connection was working. I did not install any new software or download anything. Tried getting on the internet today and nothing. My computer has an IP Address but I can't get onto the internet at all. I can't ping google. I can ping my IP address assigned, can't ping my default gateway...
I have tried a different ethernet cable and I have changed the switch the computer is connected too.
I have already uninstalled and reinstalled the ethernet drivers.
I have already performed an ipconfig /release & ipconfig /renew. I also tried ipconfig /flushdns.
I have performed a netsh winsock reset, netsh int ipv4 reset reset.log, netsh int ipv6 reset reset.log, netsh int ip reset.
After performing all of the above I am stuck with the exact same situation.
Here is my ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : ADAML-LAPTOP
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : rh.rit.edu
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . : rh.rit.edu
   Description . . . . . . . . . . . : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
   Physical Address. . . . . . . . . : 00-26-9E-00-92-8D
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::8090:b23e:6b1d:facb%19(Preferred)
   IPv4 Address. . . . . . . . . . . : 129.21.102.102(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Thursday, January 19, 2012 11:35:53 PM
   Lease Expires . . . . . . . . . . : Friday, January 20, 2012 2:35:53 AM
   Default Gateway . . . . . . . . . : 129.21.102.254
   DHCP Server . . . . . . . . . . . : 129.21.13.174
   DHCPv6 IAID . . . . . . . . . . . : 301999774
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-11-C7-D6-4A-00-26-9E-00-92-8D
   DNS Servers . . . . . . . . . . . : 129.21.3.17
                                       129.21.4.18
   Primary WINS Server . . . . . . . : 129.21.3.95
   NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . : wireless.rit.edu
   Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN
   Physical Address. . . . . . . . . : 00-1E-65-02-37-8E
Tunnel adapter 6TO4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
   IPv6 Address. . . . . . . . . . . : 2002:8115:56fe::8115:56fe(Preferred)
   IPv6 Address. . . . . . . . . . . : 2002:8115:6666::8115:6666(Preferred)
                                       129.21.4.18
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 8:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.rh.rit.edu:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.wireless.rit.edu:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
My university does not have my computer account or computer blocked.
Additionally, the link light on the computer is on and blinking.
Any help is appreciated
Fixed it...unplugged the switches, let the power stay off for about a minute. Plugged the power cord back in and it worked.
