Windows 7: wireless card problems messed with settings and in need of help!
12 Jul 2012   #1
dirty mik3
windows 7 home premium x64
hotspot shield rep told me to change network.now i cant connect
hello, this is my first post on this forum. i am in need of some help regarding the windows 7 wireless settings.
a couple of days ago i downloaded the microsoft virtual wifi miniport software to attempt to connect to both my 4g connection on my android via tethering and also my home wifi network, i finished the download and ran the .msi or whatever file but couldnt figure out what exactly to do next, so instead i went online and downloaded net32(i think), i proceeded to install the software and upon completion received an error message telling me that the driver install failed, and that i needed to type "install driver" into the programs command prompt, right as i hit enter, my whole screen went black and i got a blue error box telling me windows shut down to protect my computer, so i restarted, and everything worked fine... up untill last night.
last night i was on tinychat.com and got banned, so i decided i wanted a proxy server type of deal to prevent this from happening, so i downloaded and installed hotspot sheild. the ****ing program never even connected, i went on their website with their live chat with a representative. i asked what i should do since it wasnt connecting to their servers, he ; John, told me to temporarily disable my firewall, so i did. still nothing, so he told me to disable my antivirus, so stopped the malwarebytes proccess tree, still nothing. next, he told me to go into my processes and close out anything that looked like it might block the signal from their website, so i ended a couple processes, i was extremely weary as to why this would have any affect on the program. but still nothing, next he told me to restart my computer and get back to him, since then i have had NO internet connection. when i open up the network tray my wifi shows up with "limited access" if i disconnect and reconnect it just says it is taking longer than normal and then the same result. i went and downloaded and installed the latest driver for my wlan card and still nothing.
i have came to the conclusion that it must have been one of the programs or services that i halted/ended in task manager.
i ran "ipconfig" in cmd and it just shows the tunnel adapter stuff, nothing about my ip.
also, i connected to my ethernet and i STILL cant get a connection, if i troubleshoot the issue ittells me there is something wrong with the adapter, but i know for a fact that there is not, its something with the settings. iv reinstalled the latest driver 5x times. also, it has NOTHINGto do with my router,as my second os on this computer still connects fine,(windows 7 ultimate x64) is there a file or something that i can copy over and overwrite the old settings?
please help, i need my internet back! i have no clue what i should go about doing next as i dont have a backup saved!
thanks for reading this wall of text! any help is greatly appreciated, as i need my laptop for my work!
12 Jul 2012   #2
dirty mik3
i would seriously love any help at all, maybe some pointers of what i could do? i just need it back for work and to run my blog.
12 Jul 2012   #3
dirty mik3
okay,so i checked and my laptop wont connect to my ethernet connection either :/ i dont know what to do! if i diagnose the wireless adapter it says there is an error with it, and same with the ethernet adapter:/please! i need this for work!
15 Jul 2012   #4
dirty mik3
is there seriously no one that can ****ing help me with this? i need my laptop to work asap. i require it for work.
15 Jul 2012   #5
chev65
Quote   Quote: Originally Posted by dirty mik3 View Post
If you can post a screen shot of your ipconfig/all I may be able to help.
Messed up network settings
I have a Vodafone dongle that I use for internet connectivity, somewhere I did something to the laptops network settings and it cant connect. It's like it clashes wth a network or something. Is there a way to reset ALL the network settings to their original state? Please, someone, HELP.
Network & Sharing
Wireless connectivity problems - settings do not match etc.
Hi guys, I've had a long search for a solution to this problem, which itself seems widespread enough, however the most common solution has no effect for me. Problem is as follows: We have a network set up with many wireless devices connected, we recently switched ISP and got a BT HomeHub 3....
Network & Sharing
CCC problems, Graphical card updates and a messed up screen resolution
Computer information: Alienware Aurora ALX OS: Windows 7 64bit Prossesor: Intel i7 2.80GHz Video Card: ATI Radeon dual HD 5800 series At first I did not know how to update my video card drivers, so I basicly looked online and found Cataclyst control panel, and it was supposed to update my...
Graphic Cards
Wireless Card problems after restarting from sleep mode
I have a very annoying problem with my laptop. I have a Dell XPS M1530 and I put Windows 7 professional on it. I have set it that every time I close the lid, the computer goes into sleep mode. When I open my lid, it goes onto the log in screen. Once I log in, it recconects to my router. It...
Network & Sharing
Edimax Wireless Card EW-7718IN installation problems
I bought an Edimax WiFi card (EW-7728IN) which supports Win 7 to replace an earlier WiFi card unsupported by Win 7. In the initial installation I left Windows to find the necessary driver, which it did and reported a successful installation. However, no wireless signals were picked up and when I...
Drivers
Wireless card driver problems
I have a Marvell Libertas 802.11b/g wireless card. After about 2 hours of searching for 64bit drivers i turned up empty handed. so i downloaded drivermax to see if it could find the drivers it found the drivers and installed to my knowledge successfully but i am getting an error code 10 on the...
Drivers
