problem with driver adapter for wireless network connection
  1. Posts : 5
    windows 7 home premium 32bit
    My internet was working fine and I was connected to wifi, then it suddenly stopped working.
    I did all the troubleshoots and it discovered that there is a problem with the wireless network connection adapter. It shows that my wireless network is there and is on but won't connect to the adapter. I tried updating all the system updates, I tried restoring the system, nothing has fixed the problem! Help!!!
  2. Posts : 8,870
    Can you please post a screen shot of the ipconfig/all from this machine?
    Do you have McAfee installed on this system?
  3. Posts : 5
    I'm not sure how to view the IP configuration :s
    But yes I have McAfee installed
  4. Posts : 2,240
    Windows 7 Ultimate 64 bit
    To test a theory, disable McAfee and see if you can connect.
  5. Posts : 5
    I just did, then restarted laptop and it is still not working.
  6. Posts : 5
    I restored my settings back to when my internet was working and its fixed!
  7. Posts : 3
    Windows 7 Home premium
    I have just had the same problem and have been trying to fix for the last several hours. I tried the restore to the last point when my internet was working (3 days ago and mysteriously quit today) and did not work. Did you have to restore to a much earlier date? Any other ideas?
  8. Posts : 5
    I've only had my computer for 2 days so I chose to restore it back to when it was working. The first time I did this my computer still had McAfee installed and then the problem came back. So I restore it back to before McAfee was installed and did not install it and the problem has not returned.
    I also went to control panel>system and security>device manager>network adapters >right clicked on the adapter>properties>power management> and unticked the allow comp to turn off this device to save power
    Not sure if this help but its worked since
  9. Posts : 3
    Thanks for replying with the suggestion. Unfortunately it still isn't working so I'm going to try uninstalling McAfee to see if it makes a difference.
