Windows 7: Wireless Connection Speed limited to 54mb/s on Wireless-N equipment
03 Mar 2014   #11
joelshort
Good news!!! In the router settings I turned on "Media Prioritization" and enabled WMM Support, and changed the 5ghz band to "AC-Only" and "80ghz" and I am now getting consistent connections speeds of 500+mb/s and I've seen it go close to the max of 867mb/s!
03 Mar 2014   #12
joelshort
One more question..even though the router is set to broadcast wireless-AC Only, and I am getting connection speeds consistent with wireless-A, Windows and inSSIDer still identifies the network at being wireless-N. Any idea why?
03 Mar 2014   #13
matts6887
Windows 7 ultimate 64-bit
Quote   Quote: Originally Posted by joelshort View Post
OK, thanks. I guess I'll have to see if Linksys makes a wireless card, or if Intel makes a AC router. I still don't understand why if I set the router to wireless-N only nothing will connect. Something else to throw into the mix, I have another wireless-N router and when I connect to that router I still only get 54mb/s speed. There doesn't appear to be an option in that router's settings to go to wireless-N only.
Pulling my hair out...
Thanks again for the help.
Pulling your hair out you say?...trust me when i say been there done that!. Thats why we "geeks" are here to help
Windows 7 wireless connection Limited Access :/
So, my laptop was running low on virtual memory lately and i thought about end processing all the unnecessary programs i have installed and it seemed to work… but… one day, i actually decided to end process everything in "Performance>Resource Monitor" tab… and i think i might have done something...
Network & Sharing
Wireless connection Limited connectivity
Recently I replaced the motherboard in my aunts desktop. After loading Windows 7 Home 64 Bit and installing all the drivers, I attempted to connect to the internet via wireless adapter. I tried 2 seperate adapters and both adapters give me the same errors. Limited Connectivity. I have been...
Network & Sharing
Wireless connection limited access only on my Laptop
Can anyone help me fixing this problem? I can connect to wifi access here in our house but the problem is there are times that it connection shows LIMITED ACCESS. please help
Network & Sharing
Internet connection limited after installing new wireless adapter
I installed a new wireless adapter yesterday in the hope of increasing my internet speed. After installing the driver for the adapter I realised that my internet was no longer working. I can still see the connection but it is limited and doesnt allow me to connect to the internet. I also had a...
Network & Sharing
'Limited access'- Wireless Network connection
Hi, I cannot access my internet and don't know why. When i try to access the internet it says I have 'limited access' although I have a full internet connection. Does anyone know how to fix this please? I have a Windows 7 operating system. Thanks :)
Network & Sharing
Limited Access to wireless connection
I am getting a limited access to my SMC8014WG wireless router from my new netbook with windows 7? is there a router upgrade required? can anyone help?
General Discussion
