Windows 7: HP Laptop running same speed on ethernet cable as Wireless
05 May 2015   #1
anthony george
Hi Everyone
I wonder if anyone can help me please.
Make HP g56 Laptop
ISP Virgin Media Cable 150 meg connection
Router Virgin Media Superhub
Norton Intternet Security
No other protection is turned on
I have two computers connected to the Hub
My wifes computer fujitsu 4 core runs at the true 150 meg speed with wired ethernet cable (Perfect)
My laptop however runs at half speed with wired ethernet connection. In fact it runs at the same speed as it does when connecting via wireless to the same superhub. about 75 megs.
I have posted an ipconfig image if this is any help.
Kindest Regards
Anthony George
05 May 2015   #2
maxie
windows 7 home 64bit
Hi .... You have to remember it is up to 150mb ... You will not get this speed all the time ..
Have you just got Virgin Installed lately if so it takes some time to settle ...
Also does your Network Adapter support the top speed ? ...
As for wireless and Lan connections they can be the same speed with Virgin ... Though you should be getting more than 75mb at times ....
Virgin Media - Extremely fast broadband speeds
How do I connect laptop to internet through the ethernet cable?
my 3 year old Dell Studio laptop connects fine via wireless to home router and internet; but I cannot connect through the ethernet cable. I've done the troubleshooting; disabled/enabled the network adapter; updated the drivers. I'm using an ethernet cable which normally connects an XP, so I know...
Network & Sharing
One laptop can connect via Ethernet cable but the other one cannot?
We have 2 laptops. Both can connect via wireless fine, but only one can connect using the Ethernet cable. When plugged into the laptop which doesn't work I get the computer with a yellow "exclamation mark" triangle, which says no internet access. The working laptop is using Vista and mine, the none...
Network & Sharing
Laptop can't recognize Ethernet cable
Hi I am using a Dell Studio 1557 model. This has happened recently: I downloaded the Windows Live Essentials update yesterday and it prompted me to restart my laptop. I meant to click "Postpone" but I clicked "Restart" accidentally. This was in the middle of while I was running Firefox and...
Network & Sharing
Network speed and ethernet cable questions with wifi card question
Debating on going wireless or not: Have an Asus M4A87TD EVO that has RTL8111E PCIe Gigabit LAN controller featuring AI NET2. So Gigabit, Im thinking at least 100/1000. I am wire into my router which puts out high speed and low ping to wireless. Standard Ethernet cables supply the data pipeline, not...
Network & Sharing
BSOD with Ethernet Cable/Wireless Adapter plugged in
I have been having BSOD problems ever since I bought this computer (almost a year ago) Originally it would BSOD on File > Open but I worked around that. Not It BSODs when ever I either boot it up with some type of internet adapter plugged in, or plug some sort of internet adapter after I turned...
BSOD Help and Support
ethernet cable screwed up wireless internet?
Hi all, I am running an IBM T60P. with Windows 7. a Cisco Router "linksys E3000" My wireless has been running fine for the last few years. (win xp and win 7) Today I wanted to try something (I knew it wouldn't work but figured what the hell" I plugged in an ethernet cable and hooked it up...
Network & Sharing
