WiFi connection Problems with "free" Wifis - More Info about Problem?
  1. Posts : 136
    I have connection Problems to Wifis ...
    I want to connect for example to eduroam (free for students in Europe) ... I enter my Credentials -> but all I get is:
    Windows was unable to connect to "eduroam"
    [Troubleshot problems]
    [Tell me more about Internet connection problems]
    (= attached image)
    I get the same for "UPC Wi-Free" (=Free WiFi of my Provider): here I have to setup the connection manually, described by the provider - but the result is the same ...
    [Troubleshot problems] is helping nothing (only deactivates & reactivates WiFi network adapter) ...
    So as the screenshot is not providing so much information ...
    where in Windows do I get more information what was not matching?
    Credentials? Some Protocols? Certificates ...
    Where do I find such infos for WiFi ?
    Attached Thumbnails Attached Thumbnails WiFi connection Problems with "free" Wifis - More Info about Problem?-wifi-connectionproblem-kopie.png
  2. Posts : 7,107
    WiFi
    click on the >>Tell me more details<<<, and post that info.
    Roy
  3. Posts : 5,656
    Perhaps it is your security software interfering?
  4. Posts : 136
    Where do I find this Link?
    Do you mean "[Tell me more about Internet connection problems]"?
    This only provides some generic info about general connections problem ... like checking connection cables, restart Modem, ... useless.
    Could be, but I don't see this (should be notified).
  5. Posts : 7,107
    Hit the troubleshooter it will produce the detail.
    Roy
  6. Posts : 136
    No, It does not ...
    simply tries to fix the probelm ... only thing I can "see" is that it is deactivating the wireless adapter and activates it again ...
    Than it says something like I can try to restart the modem/access point (I can not!) and check the cables (it is wireless)
    giving two option -> check if fixed (is not) -> try fixing again (fails: and no more Info)
