Using Ethernet Cable between devices whilst using WIFI network.
Page 2 of 2 FirstFirst 12
  1. Posts : 399
    Microsoft Windows 7 Ultimate 32-bit 7601
    Are you doing this at home or at work, If you are doing this at work I highly recommend that you talk to whoever is looking after the network and ask him/her for a solution because hooking up unknown devices at minimum could set off alarms and if you setup your own router that is connected to the company network could cause connectivity and routing issues that will cripple their network.
    Might it be possible to connect one to the main network, effectively creating a sub network with just my laptop and the PLC on it?
    Yes that will work, But like I said above if this is at work don't don't connect this to the work network
  2. Posts : 7
    Windows 7 professional x64
       #12
    Right,
    Ye best not risk it. I will be at work.
    Thanks all for your replies, I think I've got enough now to find a solution.
  3. Posts : 329
    W10 Pro x64, W7 Pro x64 in VMware
    @ sml156 that clip switch in your sig is a good tip for grabbing cmd text.
  4. Posts : 399
       #14
    Using Ethernet Cable between devices whilst using WIFI network.-your-welcom.jpg
    Your Welcome
    Your Welcome
    And now for my next trick I will press the Tab Key (Only work's in cmd)
