Problem connection between laptop and pc via wifi. HELP
Let's start it fast okay?
I own a laptop and a desktop.
And, I wanted to share connection between them via wifi.
http://www.microsoft.com/windowsxp/u...02april08.mspx
This guide works on me.
But I encounter a problem while connecting to the host (My desktop)
It's like, you can't connect after you reset your connection or something, and it says "No Internet Access", and you can only connect just when your PC were freshly restart. IF you hand slipped and clicked the disconnect, you cannot connect just after you restart the PC again.
Steps repeated.
Anyone has idea about it?
Thank you
