Problem connection between laptop and pc via wifi. HELP
Do you have this kinda question too?
  • Total voters
    1
game333
11:48 AM
Let's start it fast okay?
I own a laptop and a desktop.
And, I wanted to share connection between them via wifi.
http://www.microsoft.com/windowsxp/using/networking/expert/bowman_02april08.mspx
This guide works on me.
But I encounter a problem while connecting to the host (My desktop)
It's like, you can't connect after you reset your connection or something, and it says "No Internet Access", and you can only connect just when your PC were freshly restart. IF you hand slipped and clicked the disconnect, you cannot connect just after you restart the PC again.
Steps repeated.
Anyone has idea about it?
Thank you :D
Windows 7 Starter
Windows 7 Starter
Please update your system specs. The link is in my signature.
Are all computers running Windows 7? Which computer has the internet connection? Did you install the operating systems yourself, or did they come preinstalled? Did you install the drivers, or did Windows install them automatically? Do those computers support Windows 7? Have you reviewed any Windows 7 ad-hoc guides, or just the XP guide that you found?
Windows 7 Ultimate x64 SP1Core i7-2670QM8GB DDR3 PC3-10600Intel HD Graphics 3000 + GeForce GT 540M
Dell XPS 15 L502x
Core i7-2670QM
8GB DDR3 PC3-10600
1TB 5400RPM Seagate
Thanks for replying, well I found it kinda weird.
Like, it currently can connect again after it were disconnect.
The WiFi hoster was my Desktop (XP), and WiFi client was my laptop (Windows 7)
Windows 7 comes with pre-installed.
I've checked my driver, and update the updates already.
Think I should try it for a few days more and find the solution.
Windows 7 Starter
Windows 7 Starter
Have you read any of the ad-hoc guides for Windows 7? Have you googled for "windows 7 adhoc"?
Dell XPS 15 L502x
Core i7-2670QM
8GB DDR3 PC3-10600
1TB 5400RPM Seagate
Thanks, I'll search for it now.
Windows 7 Starter
Windows 7 Starter
Windows 7 Starter
Windows 7 Starter
Try to Download driver for your wifi connection for your laptop...
64 bit Ultimate
64 bit Ultimate
