| Windows 7: Corasir Liquid cooling unit louder and hotter than two fan Noctua |
27 Sep 2012
#1 | | Windows 7 Ult X64 Melbourne, Australia |
Corasir Liquid cooling unit louder and hotter than two fan Noctua Following on from my case upgrade I installed a Corsair H100 liquid cooler.
With it set to performance, the fans are spinning at 2160 RPM. Sadly, they do not respond to the controls on the Lamptron Touch. At 0% (0v) they still spin at 2160rpm.
At 2160RPM the system is 5c hotter than it was on the Noctua NH-U9B-SE2 cooler.
It is also substantially louder.
On the slowest setting the fans spin at 2160.. Ok, so it looks like the lapmtron is telling fibs... The noise is less, but still somewhat louder than it was.
The temperature on the lowest setting is 7c hotter than on the noctua.
Instead of reducing noise and temps, I;ve actually gone backwards...
As per instructions on the Corsair video - I have set the fans to pull air into the case through the radiator.
These figures are at idle.
What am I doing wrong?
thanks
Tanya | My System Specs |
| Computer type PC/Desktop System Manufacturer/Model Number Home Made OS Windows 7 Ult X64 CPU Intel I7-3770K Motherboard ASRock Extreme 4 Memory 32GB G-Skill C11Q Graphics Card EVGA GTX 670 2GB SC Sound Card Creative Fataility Gamer Monitor(s) Displays LG E2742V x 2 Screen Resolution 1920x10880 Keyboard Logitech Wireless Mouse Logitech Wireless PSU Corsair HX 650 Case Whitebox Cooling Noctua NH-U9B-SE2 Hard Drives 256GB Vertex 4 SSD
1GB Seagate ST1000DM001 Internet Speed Dodo ADSL 2+ 1 mbps Antivirus Malwarebytes Browser IE 8 Other Info Router: D-Link 2740B |
27 Sep 2012
#2 | | Windows 7 Home Premium x64 Malmö, Sweden |
This sounds quite weird to me, I have read that the H100 gives really good temps and a lot of people on the forum is using one, I am using a H80 one myself, are you using the default black corsair fans that comes with the unit because I tried those and they are insanely loud so mine is using 2 noctua fans and thats what the other peoples here do also, the newer corsair fans are nice and performce the same as noctua fans but you get 2 fans for the price of 1.
What I would do thou is to turn the fans around so the fans pull the air out of the case and tried it like that instead to get rid of hot air building up in the case, and perhaps going over the screws again and see if it sits loose over the cpu area | My System Specs | | Computer type PC/Desktop OS Windows 7 Home Premium x64 CPU Intel Core i7 860 (Lynnfield) Motherboard Asus P7P55D (LGA1156) Memory Corsair Vengeance 9,9,9,24 1600Mhz 1.50v 2x4G Graphics Card Asus nVidia 560 GTX Sound Card Asus Xonar DG Monitor(s) Displays Acer P235H & NEC E201W Screen Resolution 1920x1080 & 900x1600 Keyboard Ducky Shine Mouse tT Theron PSU Corsair 650 Modular Case Corsair 800D Cooling Corsair H80 with Noctua fans Hard Drives 2 Internet Speed 100/100 Browser IE10 |
27 Sep 2012
#3 | | Windows 7 Ultimate 64 bit Michigan |
Quote: Originally Posted by TanyaC Following on from my case upgrade I installed a Corsair H100 liquid cooler.
thanks
Tanya TanyaC I don't think your ears are fibbing, but the Lamptron may be doing so and I wonder if not with both the temps and RPMs. I don't know if you've read it or not but a review on the Lamptron speaks of some problems with the RPM readouts anyway (under the heading One Minor Quibble). If you go into it at boot, what does your BIOS say the temps are? | My System Specs | | System Manufacturer/Model Number Homebuilt OS Windows 7 Ultimate 64 bit CPU Core i7 920 Motherboard Asus P6T Memory Corsair XMS 12GB Graphics Card Asus EAH5850 Sound Card Asus Xonar D1 Monitor(s) Displays HP 2709m Screen Resolution 1920x1080 Keyboard Microsoft Natural Ergo 4000 Mouse Microsoft Wireless Optical 1000 PSU Thermaltake TR2 RX 850 Case Lian Li PC-B70 Cooling CPU-Noctua NH D14, GPU-Stock, Case-Noctua 2x140, 2x120 Hard Drives Intel X25 120GB SSD; Western Digital Caviar Black 1TB (1), Green 1TB (2), Green 2TB (1) Internet Speed Cable Other Info HP bd 340,
HP bd 240,
Klipsch Promedia 5.1 THX |
27 Sep 2012
#4 | | |
The noctua fans are just made in a very superior manner.
The materials used are specifically made to decrease noise.
My solution, put the noctua fans on the corsair radiator.
They may be ugly to look at , but they really are probably the best made computer fans on the planet. | My System Specs | | System Manufacturer/Model Number Insane hobo technologies. ;-) OS Windows 7 x64 CPU Intel i7 2600k Motherboard Asrock z68 extreme 4 gen 3 Memory G.skill Ripjaw 16gigs @ 1866 Graphics Card Nvidia gtx580 (evga) Sound Card Integrated HD audio + hdmi Monitor(s) Displays 24" ASUS widescreen + 42" insignia Screen Resolution 1080p (1920x1080) Keyboard Microsoft wireless 3000 (v2) Mouse MS - wireless 5000 (bluetrack) PSU 1 kilowatt SLI/Crossfire rated Silverstone modular Case NZXT Phantom + additional 220 fan Cooling Zalmann Hard Drives 128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA) Internet Speed depends on if you ask me or my provider. Other Info The above information is provided as is, and the author assumes no responsibility for issues it may cause with your sanity or fanboyism. |
27 Sep 2012
#5 | | Windows 7 Ultimate SP1 X64/ linux in VM NW Florida |
Quote: Originally Posted by Maguscreed The noctua fans are just made in a very superior manner.
They may be ugly to look at , but they really are probably the best made computer fans on the planet.  My experience is the same as yours, TanyaC. I have a system with a Noctua NH-D14 and had another with a Corsair H100. The fans on the H 100 were unbearable. I changed the fans in every configuration possible. I go rid of the noise by using Noctua fans, but the H100 never kept my CPU as cool as the D14 did. I know a lot of others swear by the H100, but my experience is different. And if you go with the Noctuas, forget the Lamptron. Connect them to the PSU. You won't need a fan controller. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Home Built- Always under construction OS Windows 7 Ultimate SP1 X64/ linux in VM CPU Intel i7-3770K Motherboard Asus Maximus V Extreme Z77 Memory 8GB G.Skill Ripjaws Z DDR3-2400 (2X4GB) Graphics Card EVGA GTX 670 SC 4GB Sound Card On Board Monitor(s) Displays Asus 24" LCD Screen Resolution 1920X1080 Keyboard Logitech G510 Mouse Logitech G500 PSU CORSAIR AX850 Case Cooler Master HAF X Cooling Custom Water Cooling Hard Drives Samsung 840 Pro 256 GB, Samsung 840 Pro 256 GB, Samsung 830 256GB, Samsung HD103SJ 1TB . External HD- Black X dock esata 1TB Samsung Spinpoint, Rosewill USB 3.0 dock 1TB Samsung Spinpoint Internet Speed carrier pigeon speed Antivirus MSE/MBAM Browser ie8 Other Info 2nd Rig,Windows 7 Ultimate SP1 X64, i7-2600K, Asrock P67 Extreme 4, 8GB DDR3-2133, HAF XM case, Noctua NH-D14, Gigabyte HD6950 OC 1GB, 2 X Crucial M4 128GB, Asus 24" LED.
Laptop- Samsung RF711-SO1 17" i5-2310M, 8GB DDR3-1333, Crucial M4 and OCZ vertex2, Nvidia GT540M.Win 7 HP X64 SP1. |
27 Sep 2012
#6 | | Windows 7 Ult X64 Melbourne, Australia |
Hi all. The Noctua fans are 90mm fans, and don't fit the cooler. But I can always go and buy some 120mm fans.. They are only $29 AUD each.
I turned them around, so that they are blowing the hot air out the case through the radiator, as suggested. Temps are down 3 degrees celcius @ CPU 32c / M/B 30c.
All fans are on half speed, the H100 fans are set to the lowest setting. The noise is much better, but still not as quiet as it was before, so I'll go and pick up a couple of fans tomorrow.
@Wordsworth: When I quote temps I always quote from what the BIOS says. I typically don't rely on readings from third party programs, even the ASRock utility. The Lamptron is great for all other fan/temp readings. It wasn't really a surprise that the H100 couldn't be controlled. it has a Digital link controller, which of course, is sold separately, and can be used to manage the H100.
The only thing I don't like about this cooler is that when the system starts up or resumes from sleep it makes a noise like a jet plane taking off for about 30 - 40 seconds.
Scared the hell out of me at 4am this morning when my system woke up to do it's overnight maintenance | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Home Made OS Windows 7 Ult X64 CPU Intel I7-3770K Motherboard ASRock Extreme 4 Memory 32GB G-Skill C11Q Graphics Card EVGA GTX 670 2GB SC Sound Card Creative Fataility Gamer Monitor(s) Displays LG E2742V x 2 Screen Resolution 1920x10880 Keyboard Logitech Wireless Mouse Logitech Wireless PSU Corsair HX 650 Case Whitebox Cooling Noctua NH-U9B-SE2 Hard Drives 256GB Vertex 4 SSD
28 Sep 2012
#7 | | |
Just so you know the asrock utility IS using the bios data to give you the temps.
Just fyi. The reason it loads slowly for such a small program is because it has to grab all the data from the bios to work. | My System Specs | | System Manufacturer/Model Number Insane hobo technologies. ;-) OS Windows 7 x64 CPU Intel i7 2600k Motherboard Asrock z68 extreme 4 gen 3 Memory G.skill Ripjaw 16gigs @ 1866 Graphics Card Nvidia gtx580 (evga) Sound Card Integrated HD audio + hdmi Monitor(s) Displays 24" ASUS widescreen + 42" insignia Screen Resolution 1080p (1920x1080) Keyboard Microsoft wireless 3000 (v2) Mouse MS - wireless 5000 (bluetrack) PSU 1 kilowatt SLI/Crossfire rated Silverstone modular Case NZXT Phantom + additional 220 fan Cooling Zalmann Hard Drives 128 Samsung 830
256 Samsung 840
28 Sep 2012
#8 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
I'm using an H80 with my new i7 3770 build. I too had problems with the noisy OEM fans and have installed Nexus "Real Silent Case Fans". I can now use the new PC in my recording studio (what I built it for). | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
128GB OCZ Vertex 4 SSD for Win 8
1 TB Seagate drive for backup Internet Speed 40 MB/sec (Cable) Antivirus Microsoft Security Essentials and Malwarebytes Browser I.E9/Firefox Other Info Sonar X2 Professional 64 bit Recording Software with Roland Octa-Capture and MAudio Fast Track Ultra 8R recording interfaces, Frontier Tranzport wireless control unit, Behringer BCF2000 Control Surface.
Five USB connected optical drives for CD Audio production using Nero 11
Other systems: Desktop with i5 3550 CPU, LenovoZ560 Laptop with Win 7 64 bit HP, SP1, new iPad |
28 Sep 2012
#9 | | Windows 7 Ult X64 Melbourne, Australia |
Quote: Originally Posted by Maguscreed Just so you know the asrock utility IS using the bios data to give you the temps.
Just fyi. The reason it loads slowly for such a small program is because it has to grab all the data from the bios to work. No Drama. Interestingly, the temps reported by the ASXTU are allways 3-4c lower than what the bios reports. Speedfan and coretemp also report pretty much the same as ASXTU.
So I go by the highest reported temp and work on lowering that | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Home Made OS Windows 7 Ult X64 CPU Intel I7-3770K Motherboard ASRock Extreme 4 Memory 32GB G-Skill C11Q Graphics Card EVGA GTX 670 2GB SC Sound Card Creative Fataility Gamer Monitor(s) Displays LG E2742V x 2 Screen Resolution 1920x10880 Keyboard Logitech Wireless Mouse Logitech Wireless PSU Corsair HX 650 Case Whitebox Cooling Noctua NH-U9B-SE2 Hard Drives 256GB Vertex 4 SSD
28 Sep 2012
#10 | | |
That's odd I have an asrock board and the temps have generally been dead on.
Then again your board is a generation above mine. | My System Specs | | System Manufacturer/Model Number Insane hobo technologies. ;-) OS Windows 7 x64 CPU Intel i7 2600k Motherboard Asrock z68 extreme 4 gen 3 Memory G.skill Ripjaw 16gigs @ 1866 Graphics Card Nvidia gtx580 (evga) Sound Card Integrated HD audio + hdmi Monitor(s) Displays 24" ASUS widescreen + 42" insignia Screen Resolution 1080p (1920x1080) Keyboard Microsoft wireless 3000 (v2) Mouse MS - wireless 5000 (bluetrack) PSU 1 kilowatt SLI/Crossfire rated Silverstone modular Case NZXT Phantom + additional 220 fan Cooling Zalmann Hard Drives 128 Samsung 830
256 Samsung 840
1 Seagate 1tb (eSATA) Internet Speed depends on if you ask me or my provider. Other Info The above information is provided as is, and the author assumes no responsibility for issues it may cause with your sanity or fanboyism. Corasir Liquid cooling unit louder and hotter than two fan Noctua problems? All times are GMT -5. The time now is 12:50 PM. | |
