Windows 7: New Build with some recycled parts... Questions/Advice! Please
17 Oct 2010   #1
Ballistic
Windows 7 Ultimate 64Bit
current computer: HP PAVILION A6347C
It's specs are as follows
16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive
AMD ATHLON64 X2 DUAL CORE 5600+ 2.8GHZ
3X2GB Kingston 667MHz DDR2
Asus EN9600GT TOP
Realtek High definition Audio
2X Seagate Barracuda 320GB 7200RPM
BFG Tech GS series 500 watts
HP Brand Nettle2 mobo #MCP61PM-HM
Chipset: GeForce 6150SE nForce 430
I plan to reuse the hard drives, ram, power supply, graphics card and the cd/dvd rom
I have purchased the following items to replace the case, mobo and cpu
mobo.... Newegg.com - BIOSTAR A770E AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard
cpu.... Newegg.com - AMD Athlon II X3 450 Rana 3.2GHz 3 x 512KB L2 Cache Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX
flashy case lol... Newegg.com - NZXT LEXA S LEXS - 001BK Black Steel ATX Mid Tower Computer Case
My concerns come into play at the cpu and mobo... they are both rated for 95W Thermal Design Power... Does this mean I would have no room to play with overclocking if I chose to actually learn how to do that in the future? I also intend to attempt at unlocking the fourth core on the cpu... It's said that if I'm successful I will incur added heat that was not accounted for when AMD selected the stock heat sink and fan that they include in the package... As such I would need to buy an aftermarket heatsink and fan package... I'm partial to either the "Arctic Cooler 7 Pro" or the "Cooler Master Hyper 212"... The thing is that the mobo was very cheap.... On sale for only $50 bucks shipped so I grabbed it without really taking everything into account... turns out the ram dimms are nestled right next to the cpu slot... Because of this any of the larger aftermarket heatsinks would overlap the dimm slots... so I wonder if the heatsink pipes will be long enough to make the heat sink fins themselves actually clear the ram.... I also plan to upgrade the psu to something in the 750W range as well as upgrade the gpu to an ati 5770 but that won't happen for a few months due to lack of funds at present.... I also want to thank anyone that is willing to offer their opinion or advice addressing my concerns, I'm certain you have better things to do with your time but my level of tech knowledge is very limited.. I have pretty much only ever replaced parts like psu or graphics cards along with a few cpu replacements but exact replacements so no real brains involved in such a trivial task... I know a lot of the folks that frequent this board are true pros so I figured the best place to throw out all this information and hope for expert responses would be at the Windows 7 forum!
17 Oct 2010   #2
Darician
No objections really. It will run just fine. If anything, if you're willing to spend a bit more, you can get a quad core Athlon II X4. But apart from that, looks good.
17 Oct 2010   #3
Ballistic
Quote   Quote: Originally Posted by Darician View Post
Thank you for the reply... At this point though, it's not a viable option to go with a better cpu because I already have the cpu and mobo... The only thing that hasn't arrived yet is the case... Also thinking that I may wait on the build until I order and receive an aftermarket heatsink and fan.... Just because it seems like it would be easier to do everything at the same time, rather then go in later and possibly need to pull the mobo to attach the bracket for the aftermarket cooler... This is a problem though because I cannot decide on a heatsink and fan due to my previously mentioned concerns
18 Oct 2010   #4
Ballistic
One more thing... I have Windows 7 Ultimate on the current setup and I plan to use the same hard drives and key to activate after I'm done with the build... Will the key work after changing things up or will I have to some how get another key ?
18 Oct 2010   #5
Nigsy
openSUSE 13.1 64bit
Quote   Quote: Originally Posted by Ballistic View Post
As long as it's not OEM you will be fine, or at leat I've never had an issue.
18 Oct 2010   #6
Ballistic
It's retail
18 Oct 2010   #7
LiquidSnak
W7 Professional x64
You might not even have to muck around with re-installing windows.
Newegg.com - ZALMAN CNPS 9300AT SuperFlo CPU Cooler
I recommend Zalman coolers to everyone now that I have tried their product
18 Oct 2010   #8
Ballistic
Quote   Quote: Originally Posted by LiquidSnak View Post
Looks nice... I could get that one but are you sure it will clear the ram dimms? And what do you mean when you say "You might not even have to muck around with re-installing windows." ?
18 Oct 2010   #9
LiquidSnak
W7 Professional x64
If your install is good, you might be able to plug your HDD in and run it. If you mount that cooler so that the long way is vertical it should be no wider than the cooler mount on your MoBo.
18 Oct 2010   #10
Ballistic
So after installing and getting everything together... I could possibly just turn on my computer without reformatting and doing a clean install... I mean your saying it's not outside of the realm of reasoning that it could all work fine without reinstalling or doing anything more then adding the hdd and letting it go?
New PC Build - What Do You Think About These Parts?
Hi, I am planning on building my first custom PC. I am new at this, and I would like to know your feedback on my choice of products. What I need a PC For: Internet Browsing, Multitasking, Movie Watching, Occasional Gaming with Eye Candy. Note: I hardly ever overclock, I won't use water...
PC Custom Builds and Overclocking
Looking for Advice - Parts list for Water-Cooling
Hi folks - I have a couple water-cooling questions - thank you for whatever you care to share! Case - HAF X CPU - 980X Fans - Noctua NF-F12 WC Loop for CPU only My priorities and expectations for the WC loop:
Needing new parts and advice
I have an older HP desktop that I've upgraded the parts over time. I want to replace the motherboard and processor and get a new video card as well but the video card can come later. I want to do this as inexpensive as possible I know it's going to be a tedious job. I need to know what parts I...
Hardware & Devices
Need some advice on chosen parts for my new build
Hi there, it's been a while :D I need avice on the parts i've chosen for my new build. Will mainly be used for gaming, Internet browsing, work and music. Intel CPU Core i5 3470 Quad Core Processor - Retail - BX80637I53470 - Scan.co.uk Corsair Memory Dominator 8GB DDR3 1600 MHz CAS 9 DHX...
Need advice on a couple computer parts
So I'm basically rebuilding my computer and I need advice on a couple motherboards and brands on memory. The two motherboards I'm choosing from are these: Newegg.com - ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS Newegg.com - ASUS...
Hardware & Devices
Needs advice regarding pc parts
Hello Sf. I am building a desktop next year, which will be my first build :) So i need some advice with the parts I really want this pc to stay within 700-800 USD. This is the parts i've decided on getting so far: Case: NZXT Tempest Midi Tower Black Ram: 6 or 8 gb of ddr2 memory (Not...
Hardware & Devices
