Case air flow (Quick help please)
  1. Posts : 93
    Windows 7 Ultimate x86 7600
    Right this moment, i'm building my first rig. I've always got a DIY system but it's set up by the people working at the store.
    Not sure if i connect everything properly as i've yet to start it up. That's a different thing altogether.
    My question: I have 2 fans installed. 1 is at the usual rear panel blowing air out. I've installed another up front (basically, in-between my HDD and front panel). Should the fan up front be blowing air out or in? Which would be better?
    Thanks!
  2. Posts : 1,849
    Windows 7 x86/x64, Server 2008r2, Web Server 2008
    It should be blowing in. pulling fresh air into the system...
  3. Posts : 93
    Ah, cheers Mckill! I'll switch it around then.
    Rep'ed. :)
  4. Posts : 9,582
    Windows 8.1 Pro RTM x64
  5. Posts : 93
    Cheers Dwarf! Mine is set up exactly as you explained it. The front fan is near the bottom and the rear is up top.
    I originally thought it's best to use both fans blowing hot air out but your message made complete sense.
    I'll switch it around.
    *Can't rep you as i gave you one not too long ago. IOU1.
  6. Posts : 9,582
    You're welcome. I'm glad it helped. :)
