Windows 7: 4 fans, 3 normal headers + 1 "power fan" header. How to connect?
27 Oct 2010   #11
LiquidSnak
W7 Professional x64
Just plug them into the motherboard, you'll be fine. The only time I've bought a fan controller is when I had two fan headers on my MoBo, but five fans to run.
28 Oct 2010   #12
OneSerious
MS Windows 7 Home Premium 64-bit
In my experiance you can plug any fan in to just about any fan port. My mobo has CPU_Fan, Fan_1-3 and OPT_Fan1-3.
I've put 3 pin fans on 4 pin ports. 3 pins on 4 pin. Never had a problem.
28 Oct 2010   #13
ken9122
Win7 x64 Ultimate SP1
"reading the manual sure gave me an insight and the answer to my question was in there too XD "
When all else read the manual
The motherboard will also give you instructions and a map of where the connections are.
Ken
28 Oct 2010   #14
Solarstarshines
Quote   Quote: Originally Posted by kylehimself View Post
yes this should be no problem my after market heat sink made for my amd socket had a 3 pin instead of four i plugged one fan from the heatsink to a adapter just in case the other to the cpu fan port hell had no issues since both fans work and my system is cool
@KEN9122 I suggest manuals all the time i mean thiere there for that purpose but people never revert to reading the manual which is the main source they should be consulting first
28 Oct 2010   #15
Lebon14
So, here is the layout guys...
I scanned my manual (badly - but everything should be visible)
28 Oct 2010   #16
linnemeyerhere
Windows 7 Ultimate 64
You have all the fan headers you need ! 1-3 systems and 1-pwr. and if you want to reserve the pwr. for a memory cooler then use a splitter on one of the sys. fan headers and your off to the fan races ! Use premium ball bearing fans please.
28 Oct 2010   #17
Lebon14
Quote   Quote: Originally Posted by linnemeyerhere View Post
Whatever it is, I don't have anymore budget for anything else.
28 Oct 2010   #18
linnemeyerhere
Pun here.....That's cool as you can upgrade to great fans as the factory provided fans die.....or get too noisy!
Budgets are meant to be exceeded on these types of builds and it stimulates the economy.... so you go !
28 Oct 2010   #19
LiquidSnak
W7 Professional x64
Lol. I always budget for fans, too. Replace them as they go bad. I'm sure there will be some crazy fan technology in a few years. But serious sauce, when/if your fans go out or you get tired of them, spend a little extra money for a good brand of fan. I paid $10 each, and they are all quiet and move a frackload of air more than the cheap fans I use for budget builds when customers have a set budget.
28 Oct 2010   #20
linnemeyerhere
Too Cool ! Can't wait to see your build are you planning on snapping lots of pic's?
BSOD - Happens randomly. "Bad Pool Header", "DRIVER_VERIFIER"
Hi everyone, I recently have noticed more and more BSODs. I had this problem about 6 months ago and was able to track it down to drivers that came from Daemon tools. I cleared all that out and it fixed the issue. I don't think these new BSODs are related but they might be. This seems to be...
BSOD Help and Support
BSOD "Bad Pool Header" and "Page In Nonpage Area" Runs in Safe Mode
Hi, I am having a problem with my newer computer, I just got this rig a few months ago and never had a problem until last Thursday. It Blue Screened on me while I was installing ARC GIS 10.1. From then on it randomly crashes. (I have previously installed ARC GIS 10 and never had a problem.) I...
Random "Bad Pool Header" and "System Service Exception" BSODs
I have been getting these "Bad Pool Header" and "System Service Exception" BSODs for about a day now (the "Bad Pool Header" one tends to pop up more often then the other btw). I ran a registry cleaner which didn't work and ran memtest this morning and it showed that my memory was fine. The BSODs...
Change Start Menu "Run" & "Connect to" icons
I searched the forum for tutorials on how to change these two icons (see pictures), but couldn't find any, so if anyone have the reg key location for the icons please let me know. Thanks in Advance :)
Customization
BSOD with "usbhub.sys" and "driver power state failure"
I have been getting the BSOD since a few weeks and found out by trial and error that a USB-hub is causing the problem. Whenever I disconnect the hub before I shut off the computer I do not get the blue screen. Yesterday I also got a BSOD that mentioned driver power state failure. After I had...
Remove "Highlights" on window headers
I would like to know how to rid myself of these horrid highlights. I despise them. I loath them. I wish them to die. Anyway, I really don't like those highlights that present themselves on the title bar of windows. I've attached a picture, and what I am talking about is the diagonal streaks that...
Customization
