Windows 7: 4 fans, 3 normal headers + 1 "power fan" header. How to connect?
26 Oct 2010   #1
Lebon14
Hi guys.
I received 3/4 of my new hardware yesterday. So, today, I decided to unpack my (huge) case to check out how will connect everything and also learn to "play" with it.
So, the case has 4 fans (Lian-Li Lancool PC-K62) with 3 pins. According to my motherboard manual, there are 3 system fan headers, 1 "power fan" header and, of course, 1 CPU fan. From the 3 system fan headers, one has four pins.
So, how am I suppose to plan on how to connect them?
Thx for the help
P.S The motherboard is a Gigabyte X58A-DS3R
27 Oct 2010   #2
Lordbob75
There are plugs on the motherboard.
The CPU fan (and heatsink) should be right next to the CPU.
The others (system fans 1 and 2) are also on the motherboard, but that will depends on the layout. Check the manual, or just look on the board itself.
I don't know about the power fan...
Again, read the motherboard manual, it should show where each fan goes.
~Lordbob
27 Oct 2010   #3
Zeplash
Windows 7 Ultimate 32bit
It is possible to connect a 3pin fan on 4pin onboard,just make sure its the right fan for the job..Won't damage your Hardware you can plug it in while the system is running!!
27 Oct 2010   #4
tw33k
Windows 7 Ultimate (x64) SP1
The pwr_fan header can be used for a case fan
27 Oct 2010   #5
Lebon14
Quote   Quote: Originally Posted by Zeplash View Post
Thanks for the info. I'll be sure to check the pin layout in the manual so the pins fits accordingly.
Quote   Quote: Originally Posted by tw33k View Post
Thanks for the info. If I can use it, that means I have 4 case fans headers!
EDIT
LOL... reading the manual sure gave me an insight and the answer to my question was in there too XD
27 Oct 2010   #6
linnemeyerhere
Windows 7 Ultimate 64
Lebon14,
I would suggest you use a high quality fan controller. One power in from the PSU and all four case fans attach to it or more. Flexible fan speeds can be helpful with non premium fans for noise and heat control. The addition of temp probes which can monitor case temps is also handy. Many good makes and models available this link is just one. Good luck and I hope this addresses your connection issue.....oh it looks cool as well !
NZXT Sentry LX LCD Fan Controller SEN-001LX at TigerDirect
Added value for cable routing as it keeps this away from the mobo headers.
27 Oct 2010   #7
Lordbob75
Quote   Quote: Originally Posted by linnemeyerhere View Post
Lebon14,
I would suggest you use a high quality fan controller. One power in from the PSU and all four case fans attach to it or more. Flexible fan speeds can be helpful with none premium fans for noise and heat control. The addition of temp probes which can monitor case temps is also handy. Many good makes and models available this link is just one. Good luck and I hope this addresses your connection issue.....oh it looks cool as well !
I disagree. You would only need a fan controller if your motherboard is unable to correctly regulate the fans.
Temperature probes also cannot give an accurate reading of temperatures. I.e., they cannot give CPU core temps, just its outside temp.
His motherboard should be able to run the fans just fine (and should be auto-regulated by the motherboard anyways).
~Lordbob
27 Oct 2010   #8
DocBrown
There are also fan Y connectors (splitters) available on eBay
27 Oct 2010   #9
linnemeyerhere
My take on this a little different then Lordbob75's. I think it's better to keep the additional voltage out of the mobo and I like the clean routing of the fans to controller but I do agree that the temp. probes are just a novelty as they will only give you case and surface temps. For me I watch my vital temps with software like SIW and I would disagree that having the control over my fans is a bad thing. I will agree thought that with really great quality fans as with Noctura's the need for the controller is rather mute as they run so quiet at wide open and you don't hear a difference when slowed at least in my case. Either way its personal preference !
27 Oct 2010   #10
Lebon14
I don't want a fan controller because I don't need it. I'm not that hardcore... I just want to plug the fans >_<
BSOD - Happens randomly. "Bad Pool Header", "DRIVER_VERIFIER"
Hi everyone, I recently have noticed more and more BSODs. I had this problem about 6 months ago and was able to track it down to drivers that came from Daemon tools. I cleared all that out and it fixed the issue. I don't think these new BSODs are related but they might be. This seems to be...
BSOD Help and Support
BSOD "Bad Pool Header" and "Page In Nonpage Area" Runs in Safe Mode
Hi, I am having a problem with my newer computer, I just got this rig a few months ago and never had a problem until last Thursday. It Blue Screened on me while I was installing ARC GIS 10.1. From then on it randomly crashes. (I have previously installed ARC GIS 10 and never had a problem.) I...
Random "Bad Pool Header" and "System Service Exception" BSODs
I have been getting these "Bad Pool Header" and "System Service Exception" BSODs for about a day now (the "Bad Pool Header" one tends to pop up more often then the other btw). I ran a registry cleaner which didn't work and ran memtest this morning and it showed that my memory was fine. The BSODs...
Change Start Menu "Run" & "Connect to" icons
I searched the forum for tutorials on how to change these two icons (see pictures), but couldn't find any, so if anyone have the reg key location for the icons please let me know. Thanks in Advance :)
Customization
BSOD with "usbhub.sys" and "driver power state failure"
I have been getting the BSOD since a few weeks and found out by trial and error that a USB-hub is causing the problem. Whenever I disconnect the hub before I shut off the computer I do not get the blue screen. Yesterday I also got a BSOD that mentioned driver power state failure. After I had...
Remove "Highlights" on window headers
I would like to know how to rid myself of these horrid highlights. I despise them. I loath them. I wish them to die. Anyway, I really don't like those highlights that present themselves on the title bar of windows. I've attached a picture, and what I am talking about is the diagonal streaks that...
Customization
