Windows 7: Fan Cooling Vs Water Cooling
View Poll Results: Fan Cooling Vs Water Cooling
Air 14 70.00%
Water 6 30.00%
Voters: 20. You may not vote on this poll
10 Nov 2010   #1
YTBOY83
Windows 7 64Bit Ultimate Edition SP1
What do you think is best Fan Cooling Or Water Cooling????????
10 Nov 2010   #2
HonorGamer
Windows 8.1 Pro x64
Air cooling because i believe that water cooling is a pain to deal with. just have some extra fans, and your good to go.
10 Nov 2010   #3
YTBOY83
I read this:
Fans work and so does liquid but think about it electronics and water don't mix. If you have a leak or some issue with connections you can destroy the entire machine. If a fan goes bad it just goes bad and maybe it goes bad and you lose a processor. Water can take out the whole board and supply and all. If you do it its expensive and needs to be done by someone who knows what they are doing unless they will pay to replace everything. Liquid has a lot of advantages being that it will have a constant movement of liquid across the components which will reduce heat tremendously. The price is a bit steep for a good system but if you are a gamer or designer of some sort then it is pretty good. If you get these new fans with the cooling pipes to disperse heat and the fan regulators to adjust for the environment. Thermaltake is pretty good with them. I have a home server and i put a Thermaltake Blue ORB in the machine its massive but my machine hardly gets hot at all. The new processors will get hot quickly because of their capabilities. If you have fans/coolers on each component, intake fans on the case, and and exhaust fans on the case so you can remove the hot air from the case so it isn't just swirling around. Intake should be on the front and the side but at least the front. Exhaust should be 2 fans on the back without being butted up to something. If you have the workstation in a closed compartment or area where it isn't opened then it will cause you machine to overheat quickly. I used to run mine in a desk cabinet and i could open it and cook eggs. I recommend having it out in the open off the floor with nothing at least 8+inches from the intake/exhaust fans.
10 Nov 2010   #4
HonorGamer
Windows 8.1 Pro x64
Thats an extremely good point. With that in there i definitely go with fans XD
10 Nov 2010   #5
linnemeyerhere
Windows 7 Ultimate 64
Fans and fins can only do so much. Water and alternate methods run the whole gambit from wild external radiators to small sealed systems like my H50. If your concerned that a leak could happen and you have low or no sights on OC'g then go with fans. Water is maturing into a affordable tour de force for the extreme gamer but great thought must be given to the rewards vs risk.
10 Nov 2010   #6
pparks1
Water cooling is generally better as it's more effective. However, it has serious drawbacks like complexity, and cost.
For me personally, I'm all air cooling. And I typically just stick with whatever the case comes with (in the case of my Antec P182...it's 3 x 120mm case fans). I use the stock cooler on my Q9550 quad core and I run a small overclock (from 2.83ghz to 3.20ghz). Everything is just fine with that setup. Heat has never been an issue.
10 Nov 2010   #7
linnemeyerhere
Sometimes less is more. And sometimes more is more. lol
One other point is fans draw in lots of dirt and dust so regular cleaning of the fins, fans and components is a must.
10 Nov 2010   #8
YTBOY83
Quote   Quote: Originally Posted by linnemeyerhere View Post
Ha ha, that totally sucks when i have to do that, but compressed air helps lol. Wonder if Deodorant would work lol.
10 Nov 2010   #9
madtownidiot
Water cooling isn't.. unless you're foolish enough to use water as a cooling medium.. if there's a leak it can destroy your system. It's safer to use a silicone based transformer coolant or even cooking oil
10 Nov 2010   #10
linnemeyerhere
Excellent point it should actually be called liquid cooling as most all in the know use a non conductant liquid.
GPU Water Cooling
So my 780ti is running hot thanks to the not so shabby stock cooler. here currently it is 20C ambient temps in winter and gaming my 780 ti see 78C so come summer i am going to need to beef up cooling. so here are my current options: Swiftech H240-X with full GPU waterblock or NZXT...
PC Custom Builds and Overclocking
Water cooling GPU
So i was thining about water cooling my asus gtx 780 with the NZXT Kraken G10 and a corsair Hydro H55. ive read that doing this drops temps an absurd amount on the core, but the VRM and Mem temps either stay the same or increase. now on my 780, asus has added a VRM heat sink across all the VRMs,...
Water cooling help
There are three pumps im looking at 400lph 600lph and 800lph now im only going to be using it on the cpu for cooling im guessing 800lpm is overkill so out off the 400 and 600 lpm what would i best off be getting plus i am going to upgrade my cooling for the 7870 gpu to a water cooling block
Water cooling help
Hi guys, I think its time i done a fully water cooled system rather than a h70. I have an Antec 300, Could I fit 2 radiators together at the back and the top fan mount? I'm not sure if there will be enough room?
Water Cooling Help!
I'm trying to learn how to setup a simple water cooling heatsink for my i7-2600K. Does anybody know what items I should get to do this?
Water cooling?
What is the difference between water cooling and the fans? I think i need to know what kind of case I have or is it the mother board? Please help. ( I am including pics of the inside to help)
