I have never used Real Silent Case Fans but looks like a good fan system if it works well in fireferd's recording studio. As you can see in My Specs I use Noctua fans all over my computer. No fan controller needed just run them 100% off the motherboard or power supply. The CPU pump is hook to the Cpu fan connection on the motherboard and runs at 1450 rpm all the time with no noise. The only thing I have noticed with my H50 is the idle/low load temps are always 23c above ambient (19c +23 = 42c) but under 100% load mid to high 60c is reached O/C to 4.1. Here is a little trick I use. The O.E. case fan on top with push/pull Noctua fans on top blow around and through my DSL modem and router keep them a lot cooler, 2c above ambient. Seem like the router and modem are the only 2 things people never cool.
