corsair h60 water cooler fan noise
Page 4 of 4 FirstFirst ... 234
  1. Posts : 11,424
    Windows 7 Ultimate 64
       #31
    This could also be real handy as it won't allow air to escape so it moves through the rad the best.
    120MM Case Fan Rubber Gasket for Vibration Reduction | FAN GASKET 12CM | Distributed By MCM
  2. Posts : 2,973
       #32
    linnemeyerhere said:
    I sound like a broken record but I will only use Noc's in my builds. It's so nice not having to speed control fans just run them at full tilt and nary a whisper. I just ordered these new bad boys just to have for a NZXT Kraken I have my eyes on.
    Amazon.com: Noctua 140mm Premium Quiet Quality Case Cooling Fan NF-A14 FLX: Computers & Accessories
    NZXT RL-KRX60-01 280mm Ultra Performance Liquid CPU Cooler - Newegg.com
    That should be amazing! Better report back with results if you go this route.
  3. Posts : 11,424
       #33
    Will do. NewEgg has the Kraken 280mm unit up later today for under 100 with free delivery I'm thinking to just go for it!
  4. Posts : 2,973
       #34
    Would that be for the Intel rig?
  5. Posts : 11,424
       #35
    Yes my i7 rig but the case will be a interesting fit.
  6. Posts : 25,847
       #36
    A little trick I use for vibration. Have you ever wanted a small but yet some what thick rubber washer.
    Don't laugh now but I know where to get them free.
    Places that install new car tires. They normally replace the valve stem also. Inside every valve cap (they throw away) is a very high quality neoprene/rubber washer you can remove. They will fit over small bolts and screws and stay there. You can mount fan and lot of things using them.
    Just ask the tire place to save you a little bag of old valve stem caps.
  7. Posts : 2,973
       #37
    This is true. I used to have a sack full of them that I used on quite a few things, but I can't find them now.
