Windows 7: Do I need to put new water in my water cooling system?
25 Apr 2013   #1
Vaas
So i have heard that some water cooling systems do need new water in them every 6 months, and i have also heard that some never need to have the water replaced, so i have no idea of what brand/kind of water cooling system i have because it has no branding or anything, i got my computer custom built from ibuypower so it was professionally installed and stuff, so anyway here is a picture of it and maybe you guys can tell what i need to do, http://i.imgur.com/qxlPpCR.jpg
It looks like even if i wanted to replace the water its not built to open up, so yeah can any of you guys tell me what kind it is.
Thanks for reading this~
25 Apr 2013   #2
Layback Bear
Windows 7 Pro. 64/SP-1
Your system should of come with some kind of manual from ibuypower. If not I would contact them and find out what they recommend to use to replace the fluid and how often.
25 Apr 2013   #3
DMHolt57
This appears to be a 'closed-loop' type cooler, no opening for adding fluid. The medium inside is formulated to prevent any growth of algae. No Maintenance.
25 Apr 2013   #4
Layback Bear
DMHolt did you take a peek at the site Vaas posted?
Vaas this is a better way to post pictures and safer for the rest of us.
25 Apr 2013   #5
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
Looks like a sealed unit to me also, but even they degrade after time. What are your temps at idle and at full load ?
Strange there is no trademark on the waterblock.
25 Apr 2013   #6
Vaas
Quote   Quote: Originally Posted by AddRAM View Post
My temps at idle are 40C, Full load 57C
Any idea of how long it takes them to degrade?
@LayBackBear i did not get a manual with my system, and i will from now on post pictures that way =D
25 Apr 2013   #7
Layback Bear
Thank you Vaas.
26 Apr 2013   #8
Vaas
Bump
26 Apr 2013   #9
kbrady1979
If that is a closed loop system, then no......there pretty much isn't anything to be done to it. If there seems to be a fill/drain hole in the radiator, you may be able to flush it and refill it. Although I don't know how you would find out how much to put in it and if there is a certain type. If it is still doing it's job, I'd leave it be.
GPU Water Cooling
So my 780ti is running hot thanks to the not so shabby stock cooler. here currently it is 20C ambient temps in winter and gaming my 780 ti see 78C so come summer i am going to need to beef up cooling. so here are my current options: Swiftech H240-X with full GPU waterblock or NZXT...
PC Custom Builds and Overclocking
Water cooling GPU
So i was thining about water cooling my asus gtx 780 with the NZXT Kraken G10 and a corsair Hydro H55. ive read that doing this drops temps an absurd amount on the core, but the VRM and Mem temps either stay the same or increase. now on my 780, asus has added a VRM heat sink across all the VRMs,...
Water cooling help
Hi guys, I think its time i done a fully water cooled system rather than a h70. I have an Antec 300, Could I fit 2 radiators together at the back and the top fan mount? I'm not sure if there will be enough room?
NEW CASE + Water cooling system
Hello... Some weaks ago I've opened a thread about my games crashing, the result was that my PSU was broken and my CPU and GPU temperature are heating too fast: http://www.sevenforums.com/crashes-debugging/103813-games-crashing-black-screen.html Also my case is too small there is no room for...
Water cooling
Just went through some more of the boxes of items I bought in a pallet check out this radiator fan setup. Radiatop is bloue anodizxed with 1/2 in tubing 3 cores 2 3/4 inches thick and 11 inches long with 2 120 mm coloer master aluminum fans. Just for kicks I made a cardboard side plate and hooked...
Water cooling?
What is the difference between water cooling and the fans? I think i need to know what kind of case I have or is it the mother board? Please help. ( I am including pics of the inside to help)
