Windows 7: Looking for Advice - Parts list for Water-Cooling
06 Aug 2014   #11
Layback Bear
Windows 7 Pro. 64/SP-1
Just for some helpful information.
I replace my cpu cooler H50 with a H80. What I use to have at idle temps now I have to put a 50% load to get. 100% load tops out after 1 hour at a average of max 61C.
P6X58D-E
12gigs of Kingston 2000 O/C
Did a Repair Install to clean up some things I screwed up doing beta test.
Then decided to continue to check out things and found that my system would see 12 gigs of ram and then 8 gigs of ram and then 10 gigs of ram.
Windows sees the ram just like the bios sees the ram.
CPU-Z always sees 12 gigs. Memtest 86+ always sees 12 gigs of ram. Confusing.
While doing many hours of Memtest86 I was doing some research and found on the Asus Forum some good info. Good hell it was great info. It fixed my problem and made my system run cooler.
Memtest86+ 13.5 hours and all ram passed.
** I had installed the new cooler to tight.
Puts to much pressure on the cpu where the memory controller is and puts to much pressure on the motherboard which effects the two ram slots closes to the cpu.
**Summery:
Backed the tightness off the cpu cooler and ram is indicated in all places 12 gb as it should and it lowered the cpu temps.
I hope this information help someone.
07 Aug 2014   #12
linnemeyerhere
Windows 7 Ultimate 64
To get a total education and immersion into proper water cooling please watch a few of this geniuses video's !
30 Aug 2014   #13
linnemeyerhere
OK folks I just can't wait for these next installs. Enjoy
30 Aug 2014   #14
Layback Bear
Thank you for the video.
Personally I would of bent the tubing instead of all those 90 deg fittings. It would of looked a lot cleaner and less cluttered. It also would have less fitting to possibly leak.
I would like to know what brand of lighting he uses.
30 Aug 2014   #15
essenbe
Windows 7 Enterprise X64/Windows 10 Enterprise X64/Windows 10 Pro X64/Linux Mint
I watch a lot of his videos. He is excellent, but seems to be more interested in aesthetics than performance, but I still watch him and like him, I think you had better go in there and say money is no object. He usually uses Bitspower as much as possible. They make some outstanding stuff, but you pay dearly for it. I use some of their fittings, but the lower end ones. But, I thought that rig was excellent looking. Some of the stuff he does, I wouldn't even attempt.
30 Aug 2014   #16
Layback Bear
Oh yes he does great work. I also like his videos. Just some things I would do different.
When money is no object some great things can happen.
Do I need to put new water in my water cooling system?
So i have heard that some water cooling systems do need new water in them every 6 months, and i have also heard that some never need to have the water replaced, so i have no idea of what brand/kind of water cooling system i have because it has no branding or anything, i got my computer custom built...
PC Custom Builds and Overclocking
Water cooling help
There are three pumps im looking at 400lph 600lph and 800lph now im only going to be using it on the cpu for cooling im guessing 800lpm is overkill so out off the 400 and 600 lpm what would i best off be getting plus i am going to upgrade my cooling for the 7870 gpu to a water cooling block
Water cooling help
Hi guys, I think its time i done a fully water cooled system rather than a h70. I have an Antec 300, Could I fit 2 radiators together at the back and the top fan mount? I'm not sure if there will be enough room?
Water Cooling Help!
I'm trying to learn how to setup a simple water cooling heatsink for my i7-2600K. Does anybody know what items I should get to do this?
Water cooling
Just went through some more of the boxes of items I bought in a pallet check out this radiator fan setup. Radiatop is bloue anodizxed with 1/2 in tubing 3 cores 2 3/4 inches thick and 11 inches long with 2 120 mm coloer master aluminum fans. Just for kicks I made a cardboard side plate and hooked...
Water cooling?
What is the difference between water cooling and the fans? I think i need to know what kind of case I have or is it the mother board? Please help. ( I am including pics of the inside to help)
