Is there a quicker way to switch between win7 power options
  1. Posts : 74
    windows 7
    I regularly need to switch between "power saver" and "high performance" on my vaio laptop. I do this via going into "power options" and selecting the appropriate option when i require it. What I want to do is add a shortcut to the desktop or windows toolbar, but i cannot find a method to do this. Any ideas?
    Thank you
  2. Posts : 1,360
    win7 ultimate / virtual box
    check out this tut from brink
    If you have the Control Panel items folding out as a Menu from your Start menu (rightclick on Menu>Properties>Customize) then you can simply drag the Power Options choice onto the desktop as a link.
    If not, in Control Panel change View Options to Large Icons then drag Power Options onto desktop.
  4. Posts : 74
    windows 7
    Thanks ickymay,
    Your link for a solution worked brilliantly.
    I dough my cap to you.
    Andy
