Windows 7: Power plan - do not keep settings!
30 Jul 2013   #1
paulobao
Windows 7 Professional 64 bit
I'm running Win7Pro 64bit in a Tecra R840 laptop. My power planning regarding LCD brightness is 40% if running on batery and 100% if plugged in.
The problem is that, for some reason, I can't keep these settings and Windows (?) change it to 40% on batery and plugged in. Example: I change settings to 100% if plugged in (and my laptop is plugged in). The brightnes is at 100%. Then I shut down and start with batery. Brightness is 40%. Everything ok until now...but if I plugged in again the brightness will stay at 40% and if I go to power options I can see that the plugged in option changed to 40%!!!!
Any help will be appreciated.
Regards,
paulo
30 Jul 2013   #2
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Do you click Save Settings after changing them?
If you run HD Tune it will mess with power settings.
30 Jul 2013   #3
paulobao
Yes I save it and I do not have HD tune :-(
Cheers,
paulo
30 Jul 2013   #4
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
If you do the save power settings and reboot with it on outlet power the whole time, is it at 100%?
Just wondering if you are going to outlet power while it is still on, via battery, and at 40% setting, and that is causing it to lock 40% for both somehow.
Is that laptop running any brand specific software at bootup?
Run msconfig.exe from search box and go to the Startup tab for the list of items.
30 Jul 2013   #5
paulobao
Yes and no! If I reboot with the outlet power the brightness will remain at 100% sometimes...! Sometimes it will be at 40% brightness.
Yes it runs flashcards from toshiba.
cheers,
paulo
Power Plan Settings - Change
How to Change Power Plan Settings in Windows 7 This will show you how to change the settings for the power plan that you have selected to reflect how you want your Windows 7 computer to manage power usage. Here's How: 1. Open the Start Menu, and type powercfg.cpl in the search...
Tutorials
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
Power Plan - Restore Default Settings
How to Restore Default Power Plan Settings in Windows 7 and Windows 8 This will show you how to reset and restore all of the default Power Plans back with their default settings, or how to restore a single Power Plan back to default settings in Windows 7 and Windows 8. EXAMPLE: Default...
Tutorials
Power plan settings aren't persistent
I have my power plan set to Energy Star with display brightness set around 40% when on battery and 100% when plugged in. It seems to get reset periodically to the default which 40% for both battery and plugged in. I haven't been able to reliably reproduce the problem but every few days the...
General Discussion
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
Performance & Maintenance
