Windows 7: My pc has better parts than my girlfriends but hers is way faster why.
14 Feb 2014   #11
madcratebuilder
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
Dust buildup in lap tops is very common, when it gets bad you have to open the machine and physical clean it. Your fan is 3 years old, I would replace it while inside. You could install a new SSD while doing the fan. Then a clean install of W7 and you'll be much faster.
14 Feb 2014   #12
Computer0304
Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
I used to get cooling errors because of build up so i used a dust blower at the fan and after that, i got no more errors.
14 Feb 2014   #13
linnemeyerhere
Windows 7 Ultimate 64
Another aspect of her speed advantage could be her wireless speed. Some lappys have really poor WiFi performance. Look to find a ssd with 256gb of capacity or larger if needed and affordable. Then I used my stock spinner in an external usb powered enclosure, but then I use 64gb SD card in mine for data back up and more portable performance. Don't discount the ssd as it will also enhance battery run time as well as noise, vibration and heat!
14 Feb 2014   #14
Computer0304
I would reccomend a Samsung 840 EVO if getting a SSD.
14 Feb 2014   #15
Devlin1888
Windows 7 Home Premium 64Bit
Quote   Quote: Originally Posted by Devilz View Post
Cooling pad doesn't do the job and it make usage of laptop difficult.
Not completely correct, It depends on who make it and the overall quality, you will get some really cheap ones, and some quite expensive ones, I have tried one before and i didn't notice too much of a difference, maybe 5-8 degrees but that 5-8 degrees can be a lot if the temps are really high, also the one i used wasn't cheap but it was expensive either, somewhat mid range, it was easy to use and done the job i needed it to.
14 Feb 2014   #16
whs
Microsoft MVP
Quote   Quote: Originally Posted by bigboi972 View Post
cool guys thanks for the input is it possible to easily change the hard drive of a laptop.
Very easy. SSD - Install and Transfer the Operating System
14 Feb 2014   #17
bigboi972
Microsoft Windows 7 Professional 64-bit
I will most definitely consider replacing my fan and getting an ssd im just really worried about opening it and breaking it
14 Feb 2014   #18
whs
Microsoft MVP
To replace the disk, you only have to open the disk bay. That's easy. The fan is another story. You have to watch the wires that go to the screen. Note that a SSD produces a lot less heat than a spinning disk - in fact it produces no heat at all.
15 Feb 2014   #19
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
OP's RAM is also very slow, it's not remotely close to being a good laptop in 2014.
For replacing the hard drive with SSD I would look at this:
New PC parts (need help)
Hi everyone, before I ask for some advice on getting new PC parts I know I have posted before about getting a new PC and picking out parts but I don't have the cash so I just need to use what I got :P. First I have a AMD Rig its ok specs right now. AMD FX4100 AMD Ghost 7850 GPU ASUS...
Hardware & Devices
my girlfriends going to kill me!!!
Sooooo all I did was unplug the mouse, keybaoard, monitor, and speakers..then plugged in my gaming keyboards and mouse and now I get the message.....reboot and select proper boot device or insert boot media in selected boot device and press a key.....can anyone help me?? I'm home sick and just...
Hardware & Devices
Girlfriends laptop blue screen
My girlfriends laptop has blue screened twice recently. This most recent one is when she was moving movies off our camcorder to the laptop. I've tried to open the .dmp file using visual studio but it says it doesn't support debugging of older .dmp's? I've attached a zip with the two crash reports....
BSOD Help and Support
Where do you buy you PC parts?
Hi guys. I am from the UK and was just wondering when people on the 7 forums buy their bits and bobs? Cheers Rossy87
Chillout Room
Robotic girlfriends hit the market.
Source - Warning Will Robinson! Robotic girlfriends hit the market
Chillout Room
