Windows 7: My pc has better parts than my girlfriends but hers is way faster why.
13 Feb 2014   #1
bigboi972
Microsoft Windows 7 Professional 64-bit
I have had my pc for about 3 years. My pc specs are listed on the pc specs section of my profile. My girlfriend has had her computer for six months her specifications are listed below. Her computer is way way way faster and launches programs way faster and is just way faster but I think based on my knowledge of computers I feel that I have better parts. Why does her computer run better than my pc. Knowing this will help me make a better decision when purchasing my next pc
her specifications
Operating system windows8
Processor: intel i5-3337u cpu @1.80ghz
installed memory 8.00Gb
Gpu indel hd graphics 4000
13 Feb 2014   #2
Computer0304
Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
Well because:
1. She has a higher clock speed on her CPU.
2. She has a new 3rd gen cpu so it has newer tech.
3. She has 8gbs of RAM but you have less.
13 Feb 2014   #3
Computer0304
4. She may have a SSD.
5. Windows 8 is faster than Windows 7 for some scenarios.
14 Feb 2014   #4
whs
Microsoft MVP
What makes you think your gear is better. Her CPU has faster single core performance (most programs make no use of all the i7 cores and hyperthreads), her graphics chip is faster and her disk is probably faster too. In addition she has Win8 which is a bit faster than Win7 and a newer installation which is not yet all clogged up.
If you want more performance I recommend a SSD and a reinstall.
Clean Reinstall - Factory OEM Windows 7
Newegg.com - 250gb ssd
14 Feb 2014   #5
Computer0304
Quote   Quote: Originally Posted by whs View Post
14 Feb 2014   #6
bigboi972
cool guys thanks for the input is it possible to easily change the hard drive of a laptop.
14 Feb 2014   #7
bigboi972
I also have another questions I clean my pc regularly put it constantly gets hot is their anyway to diagnose or help with my heating issue.
14 Feb 2014   #8
Computer0304
You could get a cooling pad for your laptop.
14 Feb 2014   #9
Devilz
Windows 8.1 - 64 Bit
Cooling pad doesn't do the job and it make usage of laptop difficult.
14 Feb 2014   #10
b0bl335wa993r
Windows 7 Professional 32bit
Quote   Quote: Originally Posted by bigboi972 View Post
when I had that heating problem, I used a blower at the slowest fan speed and cleaned the system just by pointing it to blower. You'll see a lot of dust blowsout from those fan vents and other compartments. Heat problem got reduced drastically. IDK whether it's the same thing that's clooging yours, try it.
New PC parts (need help)
Hi everyone, before I ask for some advice on getting new PC parts I know I have posted before about getting a new PC and picking out parts but I don't have the cash so I just need to use what I got :P. First I have a AMD Rig its ok specs right now. AMD FX4100 AMD Ghost 7850 GPU ASUS...
Hardware & Devices
my girlfriends going to kill me!!!
Sooooo all I did was unplug the mouse, keybaoard, monitor, and speakers..then plugged in my gaming keyboards and mouse and now I get the message.....reboot and select proper boot device or insert boot media in selected boot device and press a key.....can anyone help me?? I'm home sick and just...
Hardware & Devices
Girlfriends laptop blue screen
My girlfriends laptop has blue screened twice recently. This most recent one is when she was moving movies off our camcorder to the laptop. I've tried to open the .dmp file using visual studio but it says it doesn't support debugging of older .dmp's? I've attached a zip with the two crash reports....
BSOD Help and Support
Where do you buy you PC parts?
Hi guys. I am from the UK and was just wondering when people on the 7 forums buy their bits and bobs? Cheers Rossy87
Chillout Room
Robotic girlfriends hit the market.
Source - Warning Will Robinson! Robotic girlfriends hit the market
Chillout Room
