Windows 7: Power surge damaged components or bad replacement parts. (troubelshoot
02 Oct 2014   #1
StaalZA
Windows 8.1 64bit
I was recently the victim of a power surge that fried my multi-adapter plug.
When I tried to boot my system lter and the LEDs in the case flashed for a second, and went dead. I then stripped the whole computer (even taking apart the PSU). Once I put everything together again, the system booted fine again. There was no indication that the system sustained damage and everything functioned as usual.
Later while playing BF4 I noticed that There was some type of lag, where the graphics would momentarily hang en then "rubberband" back...hardy noticeable. I contributed this to internet lag. Then I noticed that this also happened in offline games, however not always. I then made peace with the idea that some components might have taken damage from the power surge and ordered a new mobo, chip and ram.
The only parts I did not change out was the HDDs and the PSU and the GPU.
Granted the I upgraded from an old phenom II 955 the NEW MSI Z87-G43 GAMING LGA 1150 Intel mobo required both the 4Pin "CPU" connectors from the power supply. That being the only notable difference between old and new configurations, I assembled the new components and tried to boot the PC.
As soon as I hit the power button, the mobo LEDs, the Crucial Ballistix Tactical Tracer 8GB LED's and Corsair 800 GS lights up and the system fans spin to life, however there is no image on the screen. Nothing.
I then Removed my Powercolor 7950 3GB and connected the DMI connector to the MOBO screen output and booted. still no display.
I then removed 1 Module ram, then swapped it out with another. still no dice. Fairly sure it's not the ram.
I disconnected on of my HDDs swapped it round with another and tried different SATA ports on the Mobo. No dice.
I disconnected all the PSU plugs and and reconnected them and everything lights up and spins up but no image displays. I have also noticed that the CPU does not get hot/warm at all.
So, I am not sure if the new components are faulty and or if the PSU is faulty. Any ideas how I can determine/troubleshoot without buying unnecessary replacement components?
03 Oct 2014   #2
StaalZA
Windows 8.1 64bit
Well, gonna try another PSU tonight
Usb power surge
I keep getting the message one of the usb ports has malfunctioned and has exceeded its power limits or something like that. Ive never had a problem up until the past few days and now my usb ports on the top front of my case wont operate unless I reboot. Once i reboot they are fine for a short time;...
Hardware & Devices
BSOD after recent parts replacement (Error 124)
Hello good fellas! I hope you will be able to help me out with my problem, because it drives me crazy! The PC is mainly used by my parents (YouTube, Facebook, movies, etc.). The configuration was pretty slow (nothing was changed for 6 years or so), but was just fine for them. MSI motherboard...
BSOD Help and Support
A good replacement for my damaged AMD Phenom II X4 965 CPU?
Thanks to the crappy stock fan that came with the CPU (and my own incompetence), it was very easy to slip up and bend a few pins on the CPU while I was trying to clean the fan. One thing lead to another and one pin fell off (kinda easily actually). I was also under a lot of stress that day, so I...
Hardware & Devices
Power surge on USB hub port...
My system, see specs for details, started to popup this error message: "The usb device exceeded the power limit of its hub port" Clicking on the message brings up this window: There are two USB devices plugged in to the computer, keyboard and mouse in the USB 2.0 ports, when the...
Hardware & Devices
USB hub port power surge.
Well I just got a brand new medion computer (4GB ram, 1GB nvidia graphics card, dual core i5 3.0Ghz processor, etc) about 3-4 weeks ago and have had no problems till now. The problem is when i bought the computer i got a mouse and keyboard which worked with it till about 2 days ago. I have 3 USB...
Hardware & Devices
laptop replacement parts question
my laptop's touchpad currently go crazy when im controlling it what do you think is it faulty that i have to replace it or its just my system os, already tried restarting and system restore what website can i buy this replacement parts and about how much range is this touchpad my laptop is...
Hardware & Devices
