Kernel Power events are flat-out CPU power drops. Check to make sure your CPU cooler is attached fully and correctly. Also check all the power connections to the motherboard, especially the 12-pin CPU power plug.
Check to see what else is on the same power circuit as your PC. Items like appliances, window AC units and laser printers draw a large amount of power and can cause a PC to fail. Do you have an Uninterruptable Power Supply (UPS) for your PC?
The disk faults in your event list also point to possible power faults. I advise you to get the power problem corrected first then run a check disk with repair. The file structure on the disk is probably damaged/corrupt due the power loss.
The DCOM events are the least of your worries right now.
